NinerBikes
Job is continuing... Today I wrapped right carb fuel line and output line from mechanical pump. Everything FWF is going to have two wraps of foil-backed fiberglass insulation including return line to tank and fuel pressure hose. I may even insulate side of oil tank nearest the right carburetor. For now, mechanical pump will remain uninsulated – pump is near cowling front air inlet.
First photo shows single wrap of insulation and second photo shows completion with both wraps applied.
It will be interesting to note your results...
I assume you've retained some prime winter grade Mogas purchased from the local Costco sometime during the winter months?
