Got back in the air after installing my Gearbox. At about 2000 ft climbing to 2500 ft into the flight I had a Canopy latch failure. Noticed wind and light on the sides of my canopy. After a quick inspection, I saw a 4-5 inch opening at the back on the sides. First thought was I forgot close the latch, then looked up and the inside portion of the latch dropped out. Immediately started thinking and the only thing I could remember was “fly the plane” which I did.
I did not declare an emergency, just turned back and started slowing down and loosing altitude. It was a non event. Not sure if the set screw came loose or sheered off. I did have lock tight on the set screw. I checked the outside surfaces for damage after I landed with no damage
Corrected Short edited video - I had to remove the Xmradio it was blocked
