You should consider making the cowl such that the lower portion can be split longitudinally; I did this on my Showplanes cowl and it is the best mod EVER.
Intriguing idea. Any chance you could show us a picture of your mod ?
Reigniting and older thread….
RocketMan: What does FAB and CAI stand for?
Thanks for that.Filtered Air Box
Cold Air Induction
Phil
KBTF
Salt Lake City
RV10, built, flying
Murphy Moose, building. and building. and building
Don’t think you can make any deletions from kits anymore.If you go with the Showplanes cowl make sure you delete the spinner, back and mid plate for spinner as well from your finish kit order. The Showplanes Cowl uses a 15 inch spinner which you can get from your propeller supplier
I just visited the factory last month and I was under that same assumption. Definitely want to check with VANS before going much further.Don’t think you can make any deletions from kits anymore.
One of the YouTube builders just received (I believe) his finish kit and mentioned being able to delete the cowling to go with an alternate cowl.I just visited the factory last month and I was under that same assumption. Definitely want to check with VANS before going much further.
So maybe they will allow a change of cowling from the finish kit?ORDER CHANGES
Due to production and crating constraints, components cannot be added to or deleted from empennage, wing, and fuselage kits. This policy applies to both standard and quick-build kits. Firewall forward and finish kits may be customized for different aircraft configurations (slider/tip-up canopy, engine model, taildragger/conventional). However, no further additions or deletions can be accommodated. Any additional components must be ordered separately by calling Van’s Aircraft Sales Department or through the webstore at store.vansaircraft.com. Additional parts and components cannot be added to kit crates and will ship separately.
hing like that.
iction engine and one for the cold air sump horizontal induction. Here is a photo of my first RV-10 with the James Cowl.
I spoke to Van's today. They are still allowing deletions from the Finish Kits.This is on the website still:
Any handy lists of what to modify with the finishing kit? I have the showplanes cowl and CAI ducting already. Delete cowl, delete all lines/cables (TSS), and I believe a different spinner is needed?Showplanes
I went with the showplanes cowl and never looked back...
Personal preference, really, but here is why:
I like the looks better, can't stand the snorkel.
I have CAI. I do not know if it fits in the stock cowl.
I did a split lower cowl, which was fairly easy to do on the showplanes cowl.
Having flow with it now for 50 hours, I have not had any cooling issues, and removing the split cowl is incredibly easy.
Can't say how much more or less work is involved as I obviously did not use the stock cowl. I would guess a bit more, as there are some baffle mods that need to be done for the inlets and induction system.
Yes, bigger spinner. I ordered the standard baffle kit; it is a good place to start even though you will modify it.Any handy lists of what to modify with the finishing kit? I have the showplanes cowl and CAI ducting already. Delete cowl, delete all lines/cables (TSS), and I believe a different spinner is needed?
You'll need a 15 in spinnerAny handy lists of what to modify with the finishing kit? I have the showplanes cowl and CAI ducting already. Delete cowl, delete all lines/cables (TSS), and I believe a different spinner is needed?
You will need a 15” spinner for the ShowPlanes Cowl. If you shop around you can get the nice Hartzell polished aluminum spinner for less than the ridiculously high Hartzell list price (I got my 14” spinner for the James Cowl at a nice discount). Van’s will sell you this spinner but last time I asked I was able to find a better price elsewhere. The other option is to get your 15” spinner from James Cowl (he makes them for rockets and such). This is a specially made fiberglass spinner and backplate, and at a price that is a fraction of the Hartzell spinner.Any handy lists of what to modify with the finishing kit? I have the showplanes cowl and CAI ducting already. Delete cowl, delete all lines/cables (TSS), and I believe a different spinner is needed?
