Before you fork out the money on 2 x G3X touch display, you may want to know the IFR limitations the system has and what better options currently there is. I wish I knew this before my full upgrade. I absolutely love my panel but frustrated with the lack of interoperability with its own Garmin sister equipment.
I wish the G3X could change flight plans on the Navigators. The IPad with ForeFlight is able to add SID, preferred routing STARS, approaches and modify active flight plans. The G3X has less capability in that sense. I need to set the unit on Internal GPS and still does not allow for standard procedures or full approaches via the IAF. Once reverting to external GPS, the flight plan is sent over the navigator but the G3X can no longer modify it.
In contrast, I can have an IPad with a 3rd party App and it will continuously allow for adding or modifying a flight plan and send it to the Navigators. A message pops up to accept the new changes. If modifying anything on the navigator, the IPad pops up a message asking if you want to accept the new routing from the navigator.
If an IPad with a 3rd party app can seamlessly work with the 375, why can't the G3X. A competitor portable device currently provides a much reduced workload and better cockpit workflow than my dual G3X touch.
I wish the G3X could integrate better and allow full crossfill to the 375. A similar process could be integrated with messages to ensure the flight plan modification are accepted prior to going into the navigator. Switching the G3X to its internal GPS makes no sense IFR and actually increases your workload. The G3X should at the very least be able to do what ForeFlight, Garmin Pilot, Aera 760 can do. All these units are a fraction of the cost of the G3X Touch.
For those thinking of getting a Dual G3X setup with the intent of one screen being used as a MFD to create, modify or activate items on your navigator, it currently does not work. You are better off with a IPad/FF setup as your second screen or perhaps the 760 which is a fraction of the cost of the G3X.
I have sent my comments to Garmin and so far dissapointed with their replied. Absolutely love my panel but sad to see an IPad FF combo being a more powerful IFR tool than my second G3X.
Hom
Hom
