Just installed Garmin 650xi in place of a 430W. Good news is that there was no smoke when powered up. Bad news is that Section 5 of installation manual is way above my head. I have a dual screen non touch G3X, GMA240 audio and a GTX23ES transponder that talked flawlessly with the 430W. I am sure that others have upgraded navigators in a like manner, so is there a checklist available to help with 429 ARNIC and RS232 settings and other settings. I could not locate my equipment in the equipment list in the installation manual.
I had a pin to pin drawing from the 430 pins to the 650 pins and I was very careful to remove one pin at a time and reinstall each pin in 650 connectors as they were removed. I was required to add additional power and ground wires but I think all went well. I have COM just at a loss with configuration.
I also had previously installed a pin/wire in GSU73 for a go around button but it was not supported by the 430. Will the 650 support the go around function?
