SB-00023 published: RV-12/12iS Engine Mount Standoff Inspection/Replacement
Mags
I spent lots of money and sent them off to a specialist in Holland called Carmo Electronics :-)
£617 to be precise!
I didn't mention it but, amongst all the other work done last year, I also serviced the carbs and had the mags overhauled.
I cannot believe Vans is out of stock on the very day they announced the replacement part, claiming they had stuff in stock. Surely these should have been prioritised to folk with flying aircraft. I'm not happy having to wait best part of two months :-(
I don't suppose anyone has ordered one from stock which they don't need for two months?
Cheers...Keith
To clarify, the service bulletin was posted almost two weeks ago.
Around 650 hours on our RV-12, and last night we found a crack on the right side exactly where the SB diagram showed. There doesn't appear to be a crack on the left, but to be honest once I saw the one on the right I didn't look too closely elsewhere. The crack we found covers about 120 degrees or maybe more, around the top of the tube.
Sure wish we had a way to heat that hangar. It's going to be bloody cold in January.
Can you post a picture of the crack with the weld intersection in the frame.
Does anyone have a Service Bulletin log built already to track these? The list is getting longer and it seems like a good list to keep track of ones status on as parts delivery is delayed or completing them at the next annual is to take place.
Eventually. At this point it seems I won’t have a real compelling reason to go to the hangar until late January or early February.
But... it’s right where the SB illustration shows it. Just a little hairline crack, but no challenge to spot at all.
SB 00023
While I was doing the nose leg replacement a few weeks ago I checked my standoff and found a crack on the right side just as the pictures show. Easy to see when your looking for it, but would be hard to spot if Van’s hadn’t put the SB out! Was not to hard to do and not very many things to take apart as I first thought. Put new isolators in at the same time. 675 hours, not a trainer, prop balanced and carbs keep tuned.
What’s different?
There are 3 posts asking what are the improvements/changes in the -1 new standoff/truss mount. I scrolled through the site looking for the new revisions from Scott or Greg but didn’t see one. Might have missed it.
Now that I’ve received my new truss part I don’t see a noted difference. It might be inside the assembly or an improved welding process? Curious more than than anything. Thanks
The following from Van's support line: "Visually the parts should look very much the same, the difference is the wall thickness of the cross tube has been increased form .049 up to .083, almost double."
Patrick- Don't have the time at the moment to locate the post you want, but it was posted that the tubing on the new engine mount is made from tubing that has a much thicker wall dimension than the original engine mount.
Thanks for the two posts identifying the change in the NEW truss part -1. Sounds like a good fix to the original design. HAPPY NEW YEAR ALL!
No hoist needed
Just an observation. I replaced mine without using an engine hoist. I just needed someone to provide a little lift from the front of the engine to take the weight off the top bolts while I removed and reinserted them.
Not a difficult job, but it took two of us the best part of a short winter's day to removed the old unit, and the same again to install the new part.
Sorry that we missed replying on that here (I thought I had, actually). Yep, the wall thickness was substantially increased on the new part. Externally there is no real identifiable difference.
Must be a fabulously devoted friend to stand there holding your engine for 2 days ;)
For those interested, the most time consuming part of doing this job is gaining access to the aft side of the two bolts that penetrate the firewall (and that doesn't take all that long). After doing that, swapping the parts can easily be done in under an hr (if you safety wire the Adel clamps closed first....)
Two steps
As you may have noticed, I had to wait for a replacement part. In the interim I removed the old part (because I hoped - unsuccessfully - to get it welded as a temporary measure) and replaced it for the duration with two bits of threaded rod. Otherwise my friend would have had to hold the engine for two weeks!
I remembered the trick with the Adel clamps, so that wasn't an issue. It did take some time to remove the water hose which was in the way. And it takes forever with new tie-wraps to ensure that nothing will vibrate/rub or whatever.
Job done, Scottish weather has been amazing for the last few days, and we are now Covid-grounded :-(
I ordered my stand off in November. I've been at the point of being ready to hang the engine since December and was expecting it in January. Today I was told it would be mid March before I would receive it.(or later)
Should I go ahead and hang the engine now and replace this later or wait
Alan
N603NH reserved
Alan
N603NH reserved
Sorry about the additional delay Alan.
There should be no issue for you to just move ahead and install the engine so that you can continue progressing with your build. The part is easy to change with the engine installed as long as you have a means to support the front of the engine while you are doing it (a rope capable of holding 100 lbs, thrown over a rafter above the prop shaft would be more than sufficient).
I don't want to burden the staff at Van's with additional work and phone calls, but am I to understand there are further delays in shipping these parts? I ordered back in December and was told "probably late January". If it's going to be much later... well, in all honestly, I guess it means nothing, since we can't fly until it gets here, whenever that is. It would just be nice to know.
engine standoff mount
Was told this morning from Vans the engine mount standoff weldment will not ship until mid March :-(. Mine has a visible crack. Bummer.
maybe you can bum a mount from someone else who has already replaced theirs? at least for the next couple months?
I would call Van's. they are trying to get the parts out first to people that have cracks.
Alan
Yes, please do call if you have a crack and need a replacement. Our team is doing the best they can to prioritize based on that. I spoke with them yesterday about the couple folks who have posted here, but directly calling is the best way to make sure your needs are known, if you have a cracked standoff that we need to try to prioritize. Thanks!
Trick with adel clamps
Gblwy, can you or someone share the trick with the adel clamps?, is there some unique way of removing and reinstalling them?. I have fumbled with them before.
Thanks in advance
See post #39. They’re Castellated on the iS mount.
Sorry Bob, but i just don’t see that. What plans page has that? This pic is the latest version i could find.
Mine (S/N 120222) uses castellated nuts and cotter pins. In one of the Skyview installation sections I found a picture of one of the factory planes that showed the same part attached the same way. I don't know when they made the change, but originally they used cotter pins.
Received mine May of ‘19. Maybe Scott can share what prompted the change?
I second that! Mine uses cotter pins. The only issue I had was that after torqueing, I couldn't install the cotter pin for 2 reasons.. the castellation didn't line up with the drilled hole (when does it ever!?), and also there was interference between the standoff and the cotter pin during insertion.
I had to make sure the bolt's drilled hole was up/down and not left/right. So maybe with locknuts, there's a better probability that builders will get the torque closer to spec.. ?
Standard procedure for torquing castellated nuts is to first torque to minimum spec, then continue to tighten until the holes line up. This will keep you within the required torque range.
Ease of installation.
AN-310 and cotter pins has been the traditional method for these type of fasteners (large sized fasteners loaded in shear and tension), but there is now decades of service history of using just all steel self locking nuts. Many certificated aircraft are configured this way.
Many builders of other RV models have been flying for a long time with steel self locking nuts.
Other than ease of installation, I know of no other benefits one way or the other.
Limited supply of WD-01221-1
Got notice from Bruce at Vans that the first batch of new parts came in but there were not enough to satisfy my order due to orders ahead of me. I should get one from the next batch but do not know when that will happen.
WOW.
We finally had temperatures and opportunity yesterday to pull the original WD-1221 out and put in the new one. I had seen one crack during the initial inspection per the SB, but when we got it out and had a closer look it was much worse than we imagined. The right side was cracked close to 3/4 around the tube, and there was also a crack on the left side that we had not seen. It probably would have been visible with a flashlight and inspection mirror, but after seeing the first crack I hadn't looked any further.
Both cracks were exactly where the diagram in the SB showed they would be. On careful consideration, we figured that even if the tube had broken completely the airplane would not have fallen from the sky... it looks like both sides would have stayed attached, but it's still a little unnerving to see cracks like that.
Dale, what was the service life on the part. Hours? Type of flying?
A little under 600 hours currently. Three of us fly the plane, all low time pilots but nobody is abusing it. It's flown 99% off paved runways. I will say, though, that I've never been happy with the vibration level. We shipped the prop blades off to Sensenich last year for refurb and balance, when we had to replace the front half of the hub. It's better since then, but still not as good as I'd like it.
Right now we're finishing up replacing that tube, plus the trim servo and we're installing a landing light and the new throttle spring plates. I plan to re-balance the carbs again, then we're going to find a place to get the prop dynamically balanced. I don't think there is anyone around here that can do it, I'm considering a trip down to 52F to get it balanced.
These failures don’t seem to have a common root cause. All the more important to do the replacement suggested by the mother ship.
Vibration is an enemy of many things. The value of (at least one) good prop balance and carb synching should not be underestimated. I just dropped $4k on a Catto 3-blade based on some discussions i had. I'm hoping that will allow me to enjoy this airplane even more.
