Dimpling Wing Walk Doublers and Skins
Ender
Howdy everyone, hope your staying safe.
Curious how many folks dimpled instead of countersunk the wing skins, wing walk doublers, and ribs in lieu of countersinking.
Something that concerns me is that the wing is 0.32 and the doubler is 0.25, and having the dimples not be tight, or work loose over time.
Also was thinking about using the substructure dies on the doubler and rib.
Any info from folks who have done this and been “walking” on them a bunch would be much appreciated!
For what its worth, I dimpled the skin, the doubler and the rib using my DRDT-2. I am building an RV-7. They came out very nice and smooth.
Last row
The very last row of dimples (the one above the rear spar) I gave 2 lightish turns of the countersink cutter to get the three [?] layers to all sit together perfectly. I took very little material off but just enough to get the doubler to sit perfectly.
I didn't think the wing walk doublers go over the rear spar? (they end short of the spar).
The doubler extends slightly over the rear spar. The rivet call-out show longer rivets at the rear spar at the doubler location.
Dimple them
As a second time builder I highly recommend dimpling the wing walk skins (and also the rear baffle of the fuel tanks when you get to that point). They will be stronger, look nicer, easier to do, and less likely to fret over time.
