Trimming for rudder
The instructions say 1/4" from the lower holes but depict halfway between the two upper holes. After measuring and marking, the line is consistently not at the halfway point between the upper holes. Should I go with the midpoint or the quarter inch mark? See photos below.
http://imgur.com/a/UKN5LH4
The "halfway" between holes applies only to the longest set of stiffeners - each one is half the full length of the uncut stiffener. After that use the 1/4" references.
I don't see any reference to a midpoint. Can you point it out?
I just see 1/4 inch measurements for all parts and it worked fine for me. For the longest A part, the two 1/4 lines will be very close together and I used a jig saw to make that cut. All other 6 I cut with the bandsaw by first making a rough diagonal cut and then it fits for a right angle cut.
Yes there is no reference to a midway point, it just appeared that way looking at the instructions. I called Vans and confirmed I should ignore where the lines end up with respect to the upper holes.
Left/Right
Just FYI: I had first labelled the parts swapped for left and right because I interpreted the dashed horizontal center line as being a "valley" but Van's seem to express with the line a ridge so you are looking at the part standing on its flanges. Not a big deal when you later look at the assembly instruction where it becomes clear which side is left and right.
In that case I labeled them backwards. Thanks for the heads up!
