2013 RV-12 w Skyview Classic & Canopy Switch.
NinerBikes
Can it be updated and how is it done. I assume with some sort of micro switch on the latch and some wiring. Firmware is 15.4.7 now on Skyview Classic, I believe?
Ga of wire and which pin #s do you add it to on which D plug?
The RV-12 KAI (kit assembly instructions) has all of the info.
I suggest you get a copy as they are considered a supplement to the maintenance manual.
Plane does indeed come with the KAI, I assume it's in the finish kit part of the Kit Assembly instructions.
Friend also ordered the USB stick loaded version from Van's.
