This is my preliminary diagram for my RV-10
Single battery, dual alternator setup. (60amp B&C + 30amp B&C)
Backup & Master switches ON during normal ops.
Both alternators will be ON during normal ops.
ALT-1 (60amp) regulator preset at 14.4V
ALT-2 (30amp) regulator preset at 13.8V
Both regulators are LR3C-14
LV lights from regulators NOT utilized. Respective BUS voltages monitored by G3X Touch.
-MAIN BUS threshold monitoring at or below 13.8V triggers (MASTER CAUT) MAIN BUS LV
-ESS BUS threshold monitoring at or below 13.0V triggers (MASTER WARN) ESS BUS LV
I hope this is possible to setup with the G3X Touch, expert opinion is welcomed.
Shall the ESS-BUS relay fail, ESS-BUS alternate feed is provided by a diode.
EDIT: Diagram replaced with v.006 (wire size labels removed, battery capacity corrected)
EDIT: v.007 (E BUS relay replaced)
EDIT: v.008 (E BUS updated wire size & protection) peak max draw incl. intermittent draw is 33,7 Amps on the EBUS)
EDIT: v.009 (E BUS AWG updated)
EDIT: Diagram v.010 Relay substituted with cont. duty contactor
