The latest service schedule rev 9.4, says to replace the throttle return springs at 100hr. I remember the previous expansion springs had a problem breaking and required periodic replacement regardless of they were broken. Since then the springs have been upgraded to the "clock spring" type that go around the throttle shaft. I thought that solved the breakage problem. Is this replacement requirement left over from the old springs or is it still required?
