Service Letter and Options for RV-12iS and RV-12 released
greghughespdx
Last week we published four Service Letters for the RV-12iS, two of which also apply to the RV-12.
SL-00012 - May 5, 2020
Connect Garmin GA 26 GPS Antenna to MFD
Applies to: RV-12iS with the Garmin Nav/Com (IFR) Avionics Kit
SL-00011 - May 5, 2020
Optional RV-12iS Cockpit Light Dimmer Kit installation in RV-12 or RV-12iS
Applies to: RV-12 and RV-12iS (all, optional)
SL-00010 - May 5, 2020
Installation of optional Aithre Shield EX 3.0 Carbon Monoxide Detector
SL-00009 - May 5, 2020
Rotax 912iS Maintenance Port Wiring Update
Applies to: RV-12iS with WH-00133, WH-00134, or WH-00136 harnesses shipping prior to Jan. 6, 2020
G5?
This caught my eye. How do I add a G5? and where would one add one?
nice catch. I totally missed that.
Since its only being added to the 136' harness, it would seem that the factory is getting ready for the day the ASTM allows for IMC operations. The only place you could realistically mount a G5 without reworking the entire panel is over on the copilot side where the panel PTT button is..
Seems like an easy retrofit.. apparently all you need is power, and either a dedicated gps antenna or a couple of RS232 wires from the GTN650.
Now for someone to invent a way to use engine heat as pitot heat ...
