Looking for some advice from those that have been there before me. The inner and outer door shells each have six molded-in dimples that are drilled-out and used as index alignment points for the inner and outer door shells. I have drilled them out and the four lower index points for the inner and outer shells align perfectly. However the top two index points of the two shells are off by 5/16". Not sure why this is. The doors nest together very nicely with four clecos in the lower four index holes. Do I just drill new holes and keep building, or is this mis-alignment going to cause a problem later with door fitting? Anyone else experience this issue? Any advice will be appreciated.
Rick
Rick
