smithflys23
I'm wondering if I've got my prop pitched correctly. I am also wondering what others with the same prop are seeing, and what pitch pin they are using. I have the Sensenich GA for IO-360. Currently using the #6 pitch pin.
TO RPM is about 2330, in the climbout it was lightly lower around 2250. Below are some of the numbers I was seeing at cruise.
8500'
153 IAS 180 TAS
20.2" MAP
2620 RPM
8.5 GPH
377 401 389 394 CHT's
1439-1444 EGT's
9500'
150 IAS 179 TAS
19.5" MAP
2620 RPM
8.4 GPH
375 395 383 389 CHT's
1409-1417 EGT's
Am I working the engine hard enough? Am I working it to hard?
8500'
153 IAS 180 TAS
20.2" MAP
2620 RPM
8.5 GPH
1439-1444 EGT's
9500'
150 IAS 179 TAS
19.5" MAP
2620 RPM
8.4 GPH
1409-1417 EGT's
