Holes in right wingtip aluminum
E. D. Eliot
Friend
Replacing the aluminum on both wing tips. The large underside aluminum sheet has three pre-drilled holes already drilled into it which correspond to plate nut spacing. My old wing tip underside sheet did not have these three holes. My older KAI doesn't mention these three holes. Any idea as to what purpose these three pre-drilled holes are used for? Thanks.
YES
Yes for the Nav and strobe lights. It's a little different set up because of the new wiring harness.
Thank you, David
Thank you, David for the reply - it makes no sense for my Mk-1 RV-12 but I can see how those holes work for the 12is. Thanks again, Ed Eliot
