greghughespdx
Van's has released and is now shipping a new mounting tray option for RV-7/9/10 builders who need a place to install common ADAHRS/magnetometer units from Dynon/AFS and Garmin.
These mounts provide the RV-7/9 or RV-10 builder a convenient, pre-fabricated option for installation of common AHARS/ADAHRS components from Dynon and Advanced Flight Systems (SV-ADAHRS-200/201) as well as the Garmin?s GMU-11 magnetometer. When a builder is not using one of these common components, holes may be drilled in the flat support face of the bracket to accommodate other devices, if/where necessary. Determination of suitability for use with other components is the responsibility of the builder. When installed, these brackets are attached in the upper tail cone. Stacking of two Dynon/AFS ADAHRS units is supported.
Detailed information can be found in the OP-60 optional plans drawings, located on the Van's web site at https://www.vansaircraft.com/service-information-and-revisions/op-60/
The Van's part numbers for the kits are:
- RV-7/9 ADAHRS bracket kit
- RV-10 ADAHRS bracket kit
