Considering buying a GNC 420W. Anyone here using one with a Skyview system?
N804RV Well Known Member Jul 9, 2019 #1 Considering buying a GNC 420W. Anyone here using one with a Skyview system?
az_gila Well Known Member Jul 9, 2019 #2 N804RV said: Considering buying a GNC 420W. Anyone here using one with a Skyview system? Click to expand... Yes, no problems and an easy hook-up. Displays well on the Skyview and I used it as a certified ADSB source with a Dynon transponder.
N804RV Well Known Member Jul 9, 2019 #3 Thanks! I also have a Becker Nav5300 VOR/ILS. I don't think that will interface with the Skyview. But, I have the indicator for it and I think I'll have enough space on the panel.
N804RV Well Known Member Jul 9, 2019 #4 az_gila said: Yes, no problems and an easy hook-up. Displays well on the Skyview and I used it as a certified ADSB source with a Dynon transponder. Click to expand... Another question, does the com frequency/airport data flow between the GNC 420 and the Skyview?
az_gila Well Known Member Jul 9, 2019 #5 N804RV said: Another question, does the com frequency/airport data flow between the GNC 420 and the Skyview? Click to expand... No... more words added
N804RV Well Known Member Jul 9, 2019 #6 az_gila said: No... more words added Click to expand... msg rx'd
H Handclutch Well Known Member Jul 9, 2019 #7 Not the but I have one working well with a D180 and a G5. Jack
