Spark Plug Caps?
Piper J3
I was having noise in the SL40 comm radio on my RV-12. After a lot of troubleshooting I decided to replace the spark plug caps. I had a suspicion that the 5-ohm ceramic resistor may have been damaged from pulling (manhandling) the rubber caps when removing the plug wires. The rubber cap is easily deformed.
I purchased new NGK Spark Plug Resistor Cover – 90 deg Elbow Type LB05F on eBay for $49.68 for qty (8). These caps are rigid phenolic and should prevent future damage to the internal 5- ohm resistor. Installation is very simple – just unscrew old cap from wire end and screw on new cap.
Radio noise problem is now fixed…
That is an awesome tip!
Thank you for posting.
Any chance you could post a link to the caps you purchased? . . :)
