I'm looking for the cotter pin part number for the main wheel axle nut. I checked the assembly manual and the Matco manual, both reference pins but don't supply part numbers
Thanks, Rod
"The part number for the cotter pin on the axle nut is the MSC.11x2COTTERPIN. It is on our website at:
http://www.matcomfg.com/COTTERPINZP-idv-3813-35.html
It is steel and is clear zinc plated.
The same size steel pin (7/32) from other sources would work fine.
The wheel on the RV-12 is the MHMHE51B. The axle assembly is the WHLAXLE3A. They are on our website at:
http://www.matcomfg.com/MHE51BESERIE...v-2354-30.html
http://www.matcomfg.com/AXLEASSEMBLYA3A-idv-2537-1.html
Both links provide additional details.
Thank you,
George R Happ
MATCO mfg
801-335-0582 801-335-0581 (F)
www.matcomfg.com"
