Wing dimensions
My wings are complete with control surfaces and wingtip installed. 12’ 3” from inboard edge of main spar to the outer edge of the installed tip. (Tip is 17” wide at trailing edge). Leading edge of wing to trailing edge of aileron is 53” and with wings in my rolling wing rack the trailing edge of the control surfaces is 63” off the floor. You could make wing storage as compact as possible by putting the wings on the floor nose down on padding and leaving the tips, control surfaces and maybe pitot mast off.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
