-7 QB Slider fuselage, Dynon static ports.
Searching through the archives I've seen only a little bit about plumbing the static tubing near the ports.
My static ports are installed and I'm ready to run some tubing.
My question is:
Does the 'T' need to be equally spaced or is it acceptable to offset the 'T' for convenience.
Here's an example of each method (apologies to the builders I snatched these images from).
Like this? Nice and easy tubing run from here.
Or like this, easy but the final run is a little less supported.
My question is:
