Fitting Green Top
lr172
Legacy Member
I am cutting/sanding the cabin top for first fitting and have a question. The door opening on the fuse is 37". It's looking like I will taking a LOT of meat off the vertical sides of the cabin top. The inside opening of the door area is about 36 3/4" and the fuse opening is 37". This will leave me with about 1/8" of meat left on the cabin top in that area.
Is this typical for you guys? Not sure if this is a general issue or an issue with the older "Green" tops.
Appreciate any input here.
EDIT: Duh. Should have searched first. Found a post from a few months ago. Looks like I am not alone here on this issue.
Larry
