snopercod
I had one of the "lugs" (I don't know the proper name), crack off on one of my gear door hinges. I understand that RVs use lots of these MS20001-P5 extruded aluminum hinges so I'm posting this for discussion:
You will notice that the throats in these old hinges have almost no radius at the corners - I estimate .005" max, and all edges are sharp. It's my belief that a fatigue crack started in the sharp corner where the actuator arm bolts on (the dirty area in the photo). The replacement hinge stock which just arrived from ACS has a nice radius in those corners - I estimate .020" - but the edges are still sharp. So I just ordered some Craytex wheels which I intend to use in my Dremel to break all those sharp edges to eliminate stress risers.
Comments or suggestions?
