N333M
How do you determine if you have resistive float senders, or capacitive senders in your tanks?
I am beginning to calibrate the fuel levels in my RV9A for a GRT EIS system, which I didnt build, with a bit of difficulty.
On my attempt yesterday, I filled the right tank one gallon at a time, noting the reading on the EIS after each. The empty reading was 4.2 It began to change on the 4th gallon.
Then, it stopped changing at the 7th gallon, and read 5.7 each gallon there after. this isnt going to work..
Don
Don
