How does the gear react when you push it around? Does it splay out going one direction, then reverse when going the other direction? Does the tire skip once it gets to a slippery spot on the floor/ramp? If so, then you have a toe problem. Since you have excessive inside wear, I'd bet you are toe out, which is causing excessive splay, riding and wearing the inside.
