az_gila
Guys,
Does anyone have a slick method for creating an antenna stiffener plate for a top mounted antenna - comm #1 and ELT in this case.
Unlike my -6A, the -10 fuselage has a central stringer down the center of the tail cone and any large hole that is centered would seem to remove most of this stringer.
If I offset the antennae a bit from the center line I think the slight curve in the top surface would make them look crooked....
Starting on equipment selection and initial conduit/wiring installation.
