BrianDC
Well, it's time to ask for some advice from "the collective" as I'm basically trying to decide my next steps. (Regardless of the advice, I realize I am responsible for my own decisions
Currently I have finished the tailcone (Section 10), but have not riveted either of the two top skins on yet. I had a local EAA Tech Counselor visit that suggested that I determine what antennas I want to install (including magnetometers) and to NOT rivet on the top skin (F-1075) until much later.
While I can see the benefit of maintaining mostly full access to the tailcone, has anyone else done this that can provide some advice? I'm leaning towards riveting it on before I attach the tail feathers for better rigidity (and following the plans).
My other questions are regarding antenna choices and mounting locations. All along I have wanted to get a G3X Touch system, however I didn't plan to purchase any avionics or antennas until I basically done with the aircraft. Looking at some other build-logs (Looking at you rdamazio), it seems that I really am not thinking far enough ahead in my build!
I'm currently plowing through the G3X Touch install manuals and trying to spec out what I would purchase today if I had to pull the trigger and I feel like I'm missing something regarding the GMU-22 and GMU-11. I see quite a few posts of RV pilots using the GMU-22, however based on the current install manual, the GMU-11 is recommended unless my RV-10 will do over 300Kts. Is the GMU-11 just a newer option or is there a reason to go with the GMU-22?
For antennas, and things like ELT's, when is it recommended to purchase / install? I guess there is nothing wrong with holding off to install this stuff much later in the build. Worst case is I have to stuff myself in the tailcone to mount these items once everything is buttoned up?
