RV Builder Tools
DonFromTX
OK, last chance before I sell these tools individually. This was an RV12 builders kit, but could enhance any RV build. $900 and you pick up or pay the shipping:
> https://drive.google.com/file/d/0B9t...ew?usp=sharing
>> https://goo.gl/photos/twzAUBDLpg1N9wiNA
>> AVERY TOOLS RV-12 TOOL KIT ITEMS
>> PART # DESCRIPTION QTY
>> 3/32 DDS 3/32" DIMPLE DIE w/SMALL DIAM FEMALE
>> 1/8 DDS 1/8" DIMPLE DIE SET
>> #8 DDS #8 DIMPLE DIE SET
>> 1621 1/8" FLUSH SET
>> 1627 1/2" FLUSH SET
>> 1602 SP 1/8"X 1/2" CUPPED SET
>> 1017 1/8" CLECOS (325 PCS.)
>> 1016 3/32" CLECOS (50 PCS.)
>> 1012 1/2"X1 SIDE GRIPS (5 PCS.)
>> 1014 1/2"X1/2" SIDE GRIPS (5 PCS.)
>> 200 CLECO PLIERS
>> 40 #40 COBALT DRILLS (4 PCS)
>> 30 #30 COBALT DRILLS (4 PCS)
>> 19 #19 COBALT DRILLS (2 PCS)
>> #21 DRILL (1 PC)
>> 12 #12 COBALT DRILLS (2 PCS)
>> 52 #52 COBALT DRILLS (4 PCS)
>> 12X30 #30 X 12" EXTENSION DRILL
>> 1/4 1/4" COBALT DRILL (1 PC)
>> 11 #11 COBALT DRILL
>> 16 #16 COBALT DRILL (2 PCS)
>> 3 # 3 COBALT DRILLS (2 PCS)
>> 5/16 5/16 COBALT DRILL 1 EACH
>> 11/32 11/32 COBALT DRILL 1 EACH
>> 1003 BOELUBE - TUBE
>> 575 HAND SEAMER
>> 1046 SPEED DEBURRING TOOL
>> 22022 ROYAL MULTI-BURR TOOL
>> 1052 #30 C'SINK CUTTER
>> 1051 #40 C'SINK CUTTER
>> 1053 #27 C'SINK CUTTER
>> 1054 #20 C'SINK CUTTER
>> 1055 #12 C'SINK CUTTER
>> 30-120 SPECIAL #30 X 120 CUTTER
>> 19360 MICRO-STOP C'SINK CAGE
>> 7891 PNEUMATIC POP RIVET PULLER
>> P26A TIGHT SPACE POP RIVETER
>> 4910 ADJUSTABLE TORQUE WRENCH
>> UBX3 UNIBIT #3 1/4" to 3/4"
>> 6510L OFFSET SNIPS ? LEFT
>> 6510R OFFSET SNIPS ? RIGHT
>> 212 PARKER ROLO-FLAIR FLARING
>> 470-FM TRIPLE HEADED BENDER
>> 7447 S/B GEN. PURPOSE HAND PADS
>> 4510 SMALL BLOCK FOR DIES
>> 6-32 6-32 TAP
>> 3/8-16 3/8-16 TAP
>> 3/8-24 3/8-24 TAP
>> 1/4-28 1/4-28 TAP
>> 72758 6 PC. 4" SMOOTH FILE SET
>> AVERY TOOLS ADDITIONAL ITEMS
>> 11071 1/8? PLASTIC DRILL 1 EA
>> UBX1 UNIBIT STEP DRILL #1 1 EA
>> 11076 #40 PLEXIGLASS DRILL 1 EA
>> 11077 #27 PLEXIGLASS DRILL 1 EA
>> 15357 1⁄4? UNDERSIZE REAMER (0.2490) 1 EA
>> 21/64 21/64 COBALT DRILL 1 EA
>> CLEAVELAND AIRCRAFT TOOL ITEMS
>> HAND OPERATED RIVET SQUEEZER 1 EA
>> SSF1 #1 FLAT SQZ. SET 1/8?X1/2? 1 EA
>> SSF4 #4 FLAT SQZ. SET 1/4?X3/8? 1 EA
>> SSF8 #8 FLAT SQZ. SET 1/2?X3/8? 1 EA
>> SSC4 1/8? SQUEEZER CUP SET 1 EA
>> DBS40 DRILL STOP #40 1 EA
>> DBS30 DRILL STOP #30 1 EA
>> RLG1 ONE PIECE RIVET GAUGE 1 EA
>> EF60 EDGE FORMING TOOL 1 EA
>> AIRCRAFT TOOL SUPPLY COMPANY ITEMS
>> G480 DOUBLE DEBURRING TOOL 1 EA
>> FP21 DELUXE FLUTING PLIERS 1 EA
>> STEIN AIR, INC. ITEMS
>> SAT-018 MOLEX / Open Barreled Pin Crimper 1 EA
>> SAT-004 4 way indent Crimper 1 EA
>> SAT-023 Insertion/Removal Tool for D-Sub pins 1 EA
>> SAT-005 Automatic Wire Stripper 1 EA
>> SAT-006 Flush Cutters 1 EA
Squeezer
Is the >> HAND OPERATED RIVET SQUEEZER 1 EA from Cleveland tool their "Main squeez" tool? I couldn't tell from the description, but the attached picture looks like it.
That is a good deal for the tools. The prp26a rivet pullers now sell for $200-$300 depending on where one purchases.
Looks like it to me too- that's $415 for the squeezer and the yoke new. Love mine :D +1 on the edge rolling tool too.
I think most prospective builders don't know what they're looking for tool-wise when getting started (I didn't). This would be a very good start...
I am sorry for any misinformation, the squeezer is NOT the Main Squeeze, but just an ordinary squeezer.
