You don't have to lean over to see details close up like traffic. Just hit the SWAP button and have the right hand screen instantly in front of you. Swap it back in an instant.
I am not a fan of using an iPad in the cockpit. In a bubble canopy the the glare on an iPad makes it hard to see. And with it installed with some kind of mount angling toward you from the right panel, the passenger may have it for lunch in a crash landing. There are some flush mounts for the iPad which would be better but then you have the problem of the angle, and there would be no SWAP button. The dual screen panel is better. If you do a lot of cross country, subscribe to the Seattle Avionics charts and then you will have the sectionals and plates all on SkyView and clearly no need for an iPad display on the panel. I do carry my iPad usually folded up on the floor as a kind of GPS backup.
