I purchased my RV6A 2 months ago and it flys an performs amazing. The nosewheel shimmy upon landing is another story. I have read much on the problem and finally took the route of starting with doing the antisplat nosewheel bearing mod and balance and adjusting the breakout force. I found that breakout force was at 15 lbs with my fishscale. I tightened the nut 1/6 turn to the next alignment point for the cotter pin and now I'm at 40 lbs. Do I go with it and see if it eases off or drill more holes? Any help would be appreciated. Thanks
