We have a problem with a very erratic oil temp reading on a Garmn G3X system and the the sender unit is a UMA. I see that the Uma unit is a 5K thermistor unit. On the bench it measures 110 Ohm while the temp is about 20 degrees C.
First of all - is this reading right?
Secondly - I have tried to install the unit that Dynon sells. We have selected "Thermistor" in setup. At ambient it seems to be OK but seems to run away as the oil temp goes up. Will this work?
Thanking you in advance.
