Fuel Tank Sender Pics
cderk
Does anyone have any photos of the fuel tank senders installed? I'm having a heck of a time figure out how to get these set up properly. The vent line is in the way, the stiffeners are in the way - nothing seems to work properly.
Here are some photos of what I have. Seems like I'm getting between 40 and 240 ohms - full to empty.
Thanks!
Charlie
Hi Charlie, feel free to check out my blog on this, some pics you may find helpful are here:
Both tanks here, but we redid the L tank in a later post:
http://mikeandsarahrv10.blogspot.com/2015/04/fuel-tanks_29.html
The later post with the L tank again:
http://mikeandsarahrv10.blogspot.com/2015/05/fuel-tanks-proseal-bottle-6.html
I remember that it took a bit of finagling but we finally were able to get both R and L senders to move freely around obstacles and go through their full swing on the potentiometer. Feel free to reach out if you have any further questions, and best of luck! -Mike
EDIT: Is there a reason your vent line isn't routed through the hole circled here?
qs1aL3S4v3cOr9FXW_zCpyg1R_Y3an4TzO8LpnMHN00XY74ZwAZLjPnQhUaU63P2YlnWIRzceAd4mYI5jHKtOIRf_MEnHvkO7R98tOjPcB0P28hIVUDFvWlJR-4BvBpGZtB28bvH9rKvUGtmq6FKwFkvm3V24ifxGVyXo8Lis8Fb9YHzax98U48sOl-7D8cRvuu2nJc55_10-C37VlEuga2b3OVC5nudpkYOyhM8U-U-xZa2Y9Q6Z8aGVeaNmRmEoGNrjIk8CjGwrialGGe39rbMvclPiGL_UcHNDmgMM523cLPJcVGzJzxLMgvNODqAhFVVB1CnDS6GK_2u16cpS_L2UdGoGcTR4GtgPWsSaRXN0Ih_skrfOEVRfiqWMpUyEkIL5OPYjQXWnZkK-py0l61RXtiTjxfGmO9GL6qfL1acPCpTT1AU9Cnx4id-Oy4CBfivJuNPYQBZ0VgTHu9ZnmzyWh_vJtjsdCM0sfkP2WVBEzECBgYzZ5egePa61OUAwmhbK5u4s_wvW9z0fXL3FR9fgH8ahZENtKEbtXFKnYrvtEXPUR7d8ixJwTyfXu1VCR9V_fjw39O2GBshf8mH3jlLaNBiI8Zi3-G1RQ23o1gK3P6xPz0V=w1024-h768-no
Thanks for the photos mike... looks like my first mistake is that i ran the vent line in the aft-most hole, which does not look like what you did. so that will eliminate some of the bends in the line, which may make it easier for me. I also see that you put a few extra bends in the wire holding the float, which probably helped put the float in a better position to clear obstacles.
Guess I have a little more playing around to do - the tanks have definitely been the most time consuming/frustrating part so far...
Thanks again,
Charlie
I just realized in the plans (if you look at 18-6 Fig 2) your vent lines look correct, and mine do not. I'm guessing it's not a huge problem either way, as long as it is routed correctly by the fuel cap, but just wanted to point this out.
I've looked at it a few times now. Originally, I thought my method was correct, but then after I looked at your photos, I went back to the diagram and I can argue that yours looks correct. I ripped out the vent and moved it down to the same holes you used and that solved 99% of my problems. I don't know what the other holes are for... guess I would have to look ahead to see if any wires are routed there, but I kinda doubt it. Doesn't seem like either hole would make much of a difference. Your method definitely keeps the tubing in a much straighter line.
Thanks again
