Dynon?s latest SkyView software update - version 15.0 - is now available for download for all SkyView systems.
Extended Runways on Map
Highway in the Sky (HITS) & Airport Signposts in Synthetic Vision
Maintenance Log
Weight and Balance Calculator
SkyView Software v15?s new features are available as a free upgrade for all customers:
- Extended Runways Centerlines
- Highway in the Sky (HITS)
- Airport Signposts in Synthetic Vision
- Maintenance Logging
- Weight and Balance Calculator
- ADS-B Traffic and Weather from SkyView?s SV-ADSB-470 is now transmitted via Wi-Fi for use by 3rd party apps (FlyQ, Foreflight, etc)
- Airspace proximity notification. This includes airspace you are in, upcoming airspace along your flight path, and those that are above and below you.
- Activating ?Direct-To? with a runway selected under airport runway info will create a 5nm leg to the chosen runway along the extended centerline.
- VNAV from SkyView?s flight plan to your destination airport, arriving either above the airport or right at the runway itself.
- EGT/CHT widget now available in ?vertical? orientation.
- Read more about additional features and improvements.
Maintenance Log
