H HelioJoe Well Known Member Sep 22, 2016 #1 Must have had a memory loss and can not decide. What Andair fuel valve have you all been using (model)? There will be no fuel return and another silly question....is it possible to run from both tanks with the Andair choice. Thanks....Joe.
Mike S Senior Curmudgeon Sep 22, 2016 #2 HelioJoe said: another silly question....is it possible to run from both tanks with the Andair choice. Click to expand... Not if you get the correct valve. Running on "Both" is not recommended
longranger Well Known Member Sep 22, 2016 #3 Mike S said: Not if you get the correct valve. Running on "Both" is not recommended Click to expand... If EITHER tank runs dry in a low wing airplane with the pump downstream of the fuel valve, the engine quits. Think of sucking on two straws at the same time, one in a glass of water, the other open to air.
rocketman1988 Been around for awhile... Sponsor Sep 22, 2016 #4 Unless... Unless, of course, said low wing airplane has a header tank...yes, there are some...
TS Flightlines Well Known Member Advertiser Sep 22, 2016 #5 Most of us use a Andair FS20X7T valve that Vans has. Tom
H HelioJoe Well Known Member Sep 25, 2016 #6 Andair Thanks to all for the info.....now to try and convince the owner.....Joe. TS Flightlines said: Most of us use a Andair FS20X7T valve that Vans has. Tom Click to expand...
