how to repair leaking fuel tank?
dbhill916
Friend
Hi folks,
yet another set back for Hill's Air Force. I filled & calibrated the pre-assembled fuel tank last weekend, only to discover a leak. The tank came out yet again and was put on th bench for leak testing. Pressure testing (balloon, bike pump & bubble soap, per chap 37) was not successful in locating the leak. (I think my fuel cap is no longer air tight, despite plugging the vent with a 4-40 screw as suggested by someone else.)
Filling the tank with 18 gal revealed not 1, but 2, separate leaking spots. Both are very slow, but clearly present. Both are at corners: lower left front and upper right front.
Question: How should I go about making repairs to these corners? The obvious (to me) approach is to scrape/clean off the pro-seal in these areas and get down to the bare metal; clean & scuff the metal as per chap 37, then liberally apply pro-seal; and finally renew my conversations with the deity of my choice.
The other approach (which I'm hoping to avoid) is to remove the front panel from the tank in order to attempt repair from both the inside, and the outside.
Am I missing anything? Is it even reasonable/possible to repair these kinds of 'pinhole' leaks?
As always, thanks in advance for all advice,
Can you get at them from the inside by removing the large plate the fuel sensor is mounted on? I initially had a small leak I was able to get at that way.
Did you purchase the tank pre-built from the factory?? I would think Vans would make it right since it's a new tank and never flown....
Ooops, I missed that part. Kyle's right, if it's pre-built they should make it right ...
Fixing a leaking tank
First of all, don't laugh at this repair because I have done it at least six times to one of my tanks. I should mention that my problem was caused when I stripped the tank to repaint (after 11 years of flying) and too much paint the first time around. The result was a number of areas where paint was chipping off. The stripper apparently "ate" its way into the recess of the rivets and even though I washed the tank several times before painting, there apparently was a residual amount remaining around the rivet heads.
In time, the stripper "ate" through creating a vapor bubble with a small leak developing around the rivet heads. Since stripping it the last time I was reluctant to do so again. On a pure guess, I decided to cut through the paint (it is a base coat clear coat) to the aluminum with an Exacto knife in an X pattern. Once this was done, I lifted one of the "paint petals" and squeezed Harbor Freight's brand of Crazy Glue which is in a gel form and made sure it covered the bare aluminum rivet and then pushed the "paint petal" back down and let it dry. (Yes it does leave a slight bump but it matches the paint so it's not objectionably visible) Believe it or not, it fixed the leak.
I see that your leak is not visible to the outside and before you go to any labor intensive "fix", give it a try. The key is to use the gel form, clean the area of any residual fuel (acetone works well) apply the glue and let it dry. It's a cheap fix and if by chance it doesn't work for you, your only out a couple of dollars and very little labor. Good luck!
When I rebuilt my tank I found one weeping rivet down in the lower front inboard (thank goodness) corner. I used a syringe to force some sealant into the rivet. Roughly 70 flight hours since then and no leaking. My point is, some leaks can be sealed from the outside. But I'd call Van's and discuss it with them. If I'd paid for a prebuilt tank I'd expect one that doesn't leak.
Even though the plans do not discourage it, whatever others might say, DO NOT TIG weld the leak while it is full of fuel:D
I had a small leak also on my prebuilt tank. I think it was not scuffed up enough on the seams. Next time I'm building my own tank. Pro seal is not that bad to work with. Save the money for something else.
Has anyone sought out a tank manufacturer to copy the RV12 fuel tank without the rivets and pro seal application. In other wirds, a welded aluminum tank that will fit without any leaks? I'm getting sick of fixing leaks in mine.
Is anyone interested is such a tank?
I'm interested! My factory tank has leaked twice and is starting again for the third time. A welded tank sounds like the answer, except for the access port.
Hi folks,
I have had to repair several leaks like this.
all I did was scrape off some of the pro seal and clean all around the area with acetone. I then applied new pro seal,over the existing area and around the general area.
i had this same issue on two QB wings and resealed them this way and they haven't leaked since.
FWIW, when I mix the pro seal, I use a bit more than the prescribed black activator and it seems to cure much better. I have seen quite a few tanks where the pro seal has gone bad and is just gooey and sticky. My guess is the activator wasn’t mixed enough or not enough was used. Anyway, this method works for me.
good luck.
If you search back through umpteen pages of threads on fixing fuel leaks here, you'll find almost universal agreement that you can't (permanently) fix a leak by prosealing it on the outside. The leak is coming from the inside and needs to be stopped at the source. It sucks to re-open the tank, but... this is the way.
I've had it weld a a specialist-shop. Less than EUR 400 and off I went. Slightly heavier (for the thin aluminum used was unweldable, they said) so I lost about 700 grams of weight.
Never had a problem since (160 hours). FIngers crossed.
Could I have done better? Of course I could: next time I'll order one that's higher: every inch is several hours extra flight. Anyway.
I have an RV12 and have had nothing but problems with the fuel tank leaking. Does this tape go one the outside and do the job? I've never heard or seen this tape. Thanks, Joe
Hi Joe, I will add the tape to the outside of fuel tank after I am satisfied with leak testing. I then plan to prime coat the outside with Stewart Systems EkoPoxy.
