Auburntsts
So my left NS90 is acting up. Here's the symptoms:
- Strobe on - weak flash and flash pattern not sync'd with right wing or tail.
- Nav on - weak or no Red position LED
- Both Nav and Strobe on - the Red position LED strobes and the White Strobe is weak and intermittent
I've got 98 hours on the system to date and fly with the strobes on all of the time. To this point it's worked flawlessly. So before I go yanking off the wingtip or potentially the cabin flap torque tube cover panel (where the wiring for the wingtips and tail splice together) anybody got any suggestions as to where I should focus my initial efforts and what the potential issue is? I'm thinking the culprit is a grounding issue. My next guess, if the gorund proves OK, is a failed unit.
