While I was in the tunnel to clean the fuel filter and check for leaks, I discovered that the screw that is supposed to secure the fuel valve handle was not long enough to engage the stem. Also, the builder had installed the fuel valve at the top of the tunnel, and then the escutcheon sits on top of the tunnel cover. This extra thickness means the handle doesn't sit low enough for the positive lock of the handle plunger to engage the top of the fuel valve.
At the very least I would like to secure the handle to the valve, but ideally, I would like the handle to sit in it's proper position. My mechanic suggested cutting a hole large enough for the escutcheon to sit inside of the tunnel top.
How do I take the spring loaded plunger assemble out to install a longer handle screw?
Any other ideas on making the escutcheon work? With the handle extension kit solve both of these issues?
thanks
~Marc
thanks
~Marc
