OK, so I have searched all around VAF and the rest of the internet and haven't found anyone specifically mentioning this issue. I trimmed the trailing edge of the elevator tip as instructed and when I fit the tip into the elevator, there is a gap of up to a little more than 0.20" on both sides of the fiberglass between it and the elevator skin. Is this normal? If so, how does one match drill the fiberglass tip properly? Just start at one end and work through while clecoing as you go?
