papamike
It's one of those moments you just have to walk away...
I'm using the SafeAir static port kit. I drilled a 1/4" hole on the right side for the port, then realized it was aft of the bulkhead instead of forward...
You think 3" or so will be a problem? I can probably get creative with routing the tubing, putting the forward tubing run through the bulkhead, but I think the location probably should be the same on both sides.
Any ideas?
Any ideas?
