Old 12-19-2012, 01:27 PM
hendrik hendrik is offline
Smile DIY shopvac cyclone separator
I guess most of you have a proper manly shopvac. I don't. And I was tired of buying new dust bags. So a few months ago I searched for self-made separators and found this: http://www.jpthien.com/cy.htm
Decided to build my own, using a planter from IKEA, some plywood from my lathe's shipping crate, and a set of casters that were supposed to go under the second work bench which I never built. Here is the lower baffle sitting in the bucket (edit: Pierre pointed out that the drop slot in the original design is 240 degrees, while mine is 120 degrees -- this was not intentional, it's an oversight):
And the whole assembly. The PVC fittings are glued in with hot glue:
I placed everything on a small trolley so that I can move it around the shop:
I've used the thing for about half a year now, and I love it. Virtually everything stays in the bucket. Nothing makes it to the dust bag. Saw dust, chips, swarf from drilling ... you name it.
Hendrik
Club-Libelle: flying
RV-8: on hold (new job , new home , no workshop (yet) )
Last edited by hendrik : 12-25-2012 at 12:46 PM. Reason: Updated link, comment about size of drop slot
Old 12-19-2012, 02:18 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Thumbs up Small portable cyclone separator
Very nice design! There are some subtleties in your design that need not be overlooked. I assume you used 120 degrees for the length of the drop slot. How did you determine the width of the drop slot? Did you ratio the areas from the linked design? The location of the elbow relative to the drop slot seems important. I notice your elbow is not in contact with the lower baffle, whereas the linked photo and text plainly describe the elbow just touching both the baffle and the side. Is this of any consequence?
I like your design. I have some experience with installing cyclone collectors in an industrial plant many years ago and have been intrigued by them since. But I never thought they were practical on such a small scale. Thanks for sharing with us.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 12-19-2012, 02:37 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I would think a curved baffle between the intake and exhaust ports would make the swirl a lot stronger.
Baffle needs to start at the end of the 90* fitting on the intake, and stop at the beginning of the drop slot. Basically follows the arc of the threaded bolts, height to touch both discs,
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-20-2012, 12:45 PM
speyers's Avatar
speyers speyers is offline
Default Cool!
Neat idea. Nicely done. I bet it works great.
-David
David Speyers
CFII, A&P IA
Arlington, TX
Old 12-20-2012, 09:33 PM
wjb's Avatar
wjb wjb is offline
This is really cool! After reading the post, I spent about an hour reading up on the physics of operation of these things ... very interesting! I'm gonna build one for all those aluminum chips!
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 12-21-2012, 12:00 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Hey...I'm astonished and jealous of that beautiful wood floor. Is that your shop floor where you build your RV?
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 12-21-2012, 01:01 PM
pierre smith's Avatar
Seems to me that your baffle is reversed from the drawings. He has 240 deg of drop slot, where yours has just 120 deg of slot, just the reverse. Or not?
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 12-21-2012, 01:02 PM
rv7boy's Avatar
Forum Peruser
Cool A swirling question
One other question I've pondered...if the cyclone separator were built for use in the southern hemisphere, say in South Africa or in Australia, should the cyclone be in the opposite direction?
Any Coriolis aficionados out there?
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 12-21-2012, 01:06 PM
rv7boy's Avatar
Forum Peruser
Seems to me that you baffle is reversed from the drawings. He has 240 deg of drop slot, where yours has just 120 deg of slot, just the reverse. Or not?
Best,
Good eye, Pierre! I believe you are correct! I totally missed this. As I said before there are some design subtleties that should not be overlooked. Hendrik, we need your comment on this since you are the original poster. Was the drop slot change intentional or an oversight?
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 12-21-2012, 01:13 PM
rv7boy's Avatar
Forum Peruser
Here's a link to a page containing detailed instructions by the original author as well as a discussion page. The photos clearly show 240* of drop slot as Pierre pointed out.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
