Old 04-16-2010, 09:38 AM
ratc's Avatar
ratc ratc is offline
Default Rotec Engineering TBI ?
Whilst Looking at alternatives to carburettors and FI on Lycoming 320 engines I came across the Rotec TBI.
Has anyone used the TBI 40-4?
It appears to be the only one which is approved for mogas (which has great appeal to me). Not to mention that it looks beautifully engineered.
For those who have gone before the pros and cons of TBI operations and installation would be useful. Thanks.
Andy
RV-4
#4411
G-RATC
Old 04-16-2010, 08:13 PM
Snowflake's Avatar
I'm interested in this as well, i'd be considering it for an RV-6 though... Also an O-320. E2D, if it matters.
Rob Prior
Old 04-16-2010, 08:45 PM
N941WR's Avatar
N941WR N941WR is offline
Try searching on "Rotec TBI". At least one RV builder was installing it when they first made this announcement last year.
Not much has been said about it since.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-16-2010, 10:05 PM
petehowell's Avatar
Default I have one....
I have been flying too much to take the time to install it. Probably next annual.
RocketBob has one for his -6 and is further along on the install. Maybe he will chime in.
Pete
Amateur Plane - RV-9A N789PH - 2450+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 04-16-2010, 10:59 PM
Dmadd Dmadd is offline
FWIW
a pal put one on his O-320 powered Swick Taylorcraft. We took my RV-4 FAB and copied it for the install. He LOVES the thing. Gets way better fuel economy than the pressure carb that came off the airplane. Idles better, and runs better.
Really neat design. Uses nylon gaskets for the slide, and the fuel metering is done with a really unique and incredibly simple design. I'm going to put one on the four as soon as the marvel dribbler needs a rebuild...
Old 04-17-2010, 01:03 PM
ratc's Avatar
Smile Rotec TBI
Dennis, thanks for the input, it does sound promising!
You have answered one of the questions I've posted to Rotec regarding the use of the Vans FAB. No rush, but if there is any chance of a photo of the FAB modification/installation it would be a useful reference.
More importantly having seen one do you think there will be any major issues fitting it in/under the -4 standard 0-320 cowls?
Andy
RV-4
#4411
G-RATC
Old 04-17-2010, 02:48 PM
Tony Spicer Tony Spicer is offline
Yep, it's unique. Ben Ellison has been building them for over 25 years. Patent ran out. The Rotec is a copy.
http://www.ellison-fluid-systems.com/
Tony
Old 04-17-2010, 04:00 PM
SvingenB SvingenB is offline
Tony
Same principle, but different design (like a V6 vs a straight 6). Rotec TBI is a sliding carb with a totally separate fuel pressure regulator that when used together makes up a complete single point fuel injection or TBI. It is a simpler design than the Ellison.
Besides, at less than half the price, and can run on mogas and manufactured by an active team using modern manufacturing methods (unlike the stale Ellison), there really is no comparison.
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
Old 04-17-2010, 04:43 PM
To date, there have been no O-320 PIREPS posted on VAF. So how can you say there's no comparison? Google can't find any either.
Tony
Old 04-17-2010, 05:27 PM
Tony,
My understanding is that it is a lot like Ellisons design, but improves a few key areas with some materials that didn't exist when Ellison designed his. I'm relying on my pals explanation here, be cause he has owned both, but I've only seen the Rotec.
D
Tony
