Originally Posted by Al RV8
Were you guys able to use the same Hartzell BA spinner with the Hartzell composite? Also, any additional performance info we can get would be greatly appreciated.
Thanks!
We could have used our existing spinners, but we all went with the very cool and sexy Hartzell polished spinners. We are in the entertainment business. Looks matter.
You would have to make your cut out of your existing Vans spinner of the root slightly larger to accommodate the larger root of the composite blades. Just a little bit of filing if you want to keep your Vans spinner thats already fitted.
The team had a number of different props. From BA to old fat paddle to WW. All c/s props of different shapes and sizes. As a general set of observations;
1. Significant reduction in weights going from metal. This improved handling of stick forces and formation aerobatic maneuvers.
2. Significant improvement in smoothness
3. Significant improvement in static thrust. This was particularly noticeable in the vertical during aerobatic maneuvers and on take off. ~200' reduction in T.O. distance.
4. Significant improvement in acceleration against the metal props. Think faster spool up time of RPM. Also noticeable in the vertical.
5. Similar cruise speeds
6. Similar top speeds with a couple reporting 1-2kts loss in very top speed
7. Improvement in ramp appeal. They just look good.
8. Improvement in blade life. These blades are certified unlimited service life.
Thats it in a nutshell.
