Old 09-09-2009, 12:02 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default RV-3B Flap Trimming Question
This question is for anyone who happens to have access to a -3B flap that has already been trimmed on the inboard end to fit a fuselage....
As with most all of the QB flaps, they leave the skin very long on the inboard end so that it can be trimmed to meet the fuselage. I want to do a rough trim of a couple inches in order to get me better access to rivet on the flap actuator reinforcing plate and mount - just to take off the excess, not to try and do a finished trim (the fuselage does not yet exist). i was wondering if anyone would be able to give me a rough estimate of how much skin is left beyond the inboard flap rib? The lower surface measurement is fine - it will be longer than the top.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-09-2009, 05:15 PM
Tony Spicer Tony Spicer is offline
Here's a couple of photos that might give you an idea:
http://picasaweb.google.com/tonyboyt...40199274333330
http://picasaweb.google.com/tonyboyt...40164914594946
Cut the top skin back too far and the RV-8 flap fairing won't cover the top edge. The bottom skin on mine wasn't long enough to fair into the fuselage so I added a piece. It's held up fine for 200 hours.
http://picasaweb.google.com/tonyboyt...40130554856562
Tony
Old 09-09-2009, 06:42 PM
Ironflight's Avatar
Perfect Tony - just what I needed! (I do intend to use the -8 fairing - worked for me befoe... )
Paul
Paul F. Dye
