overvoltage protection
rv72004
I have the Vans F/F kit with a 60 amp alternator and built in regulator. The instructions say that a overvoltage protection is not needed and is advised against as the alt has a built in o/v protection.
As usual someone is trying to convince me to use a exterior o/voltage protector.
My question is , is it really needed? Also can the alternator pack in and toast my beautiful glass panel ?
Two choices
Basically you have two choices:
1) trust that your alternator will not have an OV event. These do seem to be very unlikely on new alternators.
2) put in some kind of OV protection. There is the crowbar method (see http://www.bandc.biz/), the manual method (CB in cockpit, and pilot to pull it when OV buzzer goes off), and the perihelion design method (see http://www.periheliondesign.com/). There are probably other methods that I don't know about.
If the worst thing that could happen with an OV even is that I smoke my electronics, then I would just trust the alternator, but make sure it is new. Howeve, I'll be flying with an auto conversion engine, and it needs electrons as badly as it needs gasoline. If I smoke the engine computer, I'm a glider pilot. I don't feel comfortable risking that, so I'm actively looking for a good solution.
Bob Nuckolls (http://www.aeroelectric.com/) is looking into the best way to control IR alternators, and will probably come up with some good suggestions in the coming months. If that does not happen, or I'm ready to fly before it does, then I'm going with the Perihelion Design system for IR alternators.
OV protection
As usual, there is no guaranteed answer. Here is a short summary of what I've learned over the past year of trying to make the same decision.
There is an ongoing discussion about IR alternators on the AeroElectric Matronics list. The big issue is getting details on how the built-in OV protection works to determine failure modes. "Can" it fry your panel - of course - if the wrong things fail, but that's true of any system. The question is, are there any components in the IR system that can allow or cause OV and also defeat the protection? No one seems to have the info to definitively answer that, and it may be different for different IR's.
A number of Van's alternators with external OV protection have fried when the B-lead contactor was opened while the alternator was under load, so obviously Van's doesn't recommend that configuration. The B-lead contactor is needed because the field coils are self-exciting once started (no way to turn off the alternator, other than disconnect the B-lead, in case of OV). If you decide to use external OV protection with a B-lead contactor, be sure to leave your Alt switch ON until the engine is shut down to avoid this problem (pretty simple solution if you want the extra protection).
Bob Nuckolls is gearing up to start playing with IR's to get some answers, but I suspect it will be a while before any answers are forthcoming. And again, it may not apply to ALL IR's.
OV is a pretty rare event, and the automotive world can't stand high failure rates on millions of vehicles with lots of on-board electronics, so many are comfortable with the protection built-in to the IR's.
One thing you can do (I plan to) is add a transorb to the B-lead which supresses voltage spikes to 18V. Eric Jones sells these as "WhackJacks" (perihelion.com). It's not the same as OV protection, but it hopefully will provide some protection for the electronics if all else fails.
I'm an AE, not an EE, so I know enough about electronics to be dangerous, but not enough to make the tough calls, like this one. Statistically, you're OK to use the built-in protection. It all comes down to your comfort level.
Dennis Glaeser
7A - Wings done! Fuselage coming...
Recent (secondhand) Experience
A fellow EAA'er at our local chapter just had a horendous experience with the alternator you mentioned... things were going fine till he happened to switch off and on his alternator in flight, when all heck broke loose! and he fried about 9k worth of his brand new panel! He did not have external overvoltage protection! I personally installed the BC Specalties system mentioned in the above replies in my "6" and am very happy that I did this, I would have a local alt. shop remove all internal voltage regulation from your alt. and go only with the BC Spec. regulator... not only does it have failsafe overvoltage protection, but it also has a nifty way to do fine tuning on your alternator voltage output...
Good luck
Dale - RV6 N833DW
Which alternator? What model? Where did he get it? How was it wired? How did he turn it off and on? This is the problem with second-hand info. It's incomplete.
I still don't understand why a regulator that is located outside of the alternator case is more or less reliable than one that is located inside the case. They are both regulators.
Just when you thought it was safe to go back to your web browser!
Maybe we should start a thread on a less-controversial topic...like primers or nosewheel vs. tailwheel. :eek:
The debate on this topic has reached almost epic proportions on the Aeroelectric List. I hope this one stays civil and technically focused...I still have a lot to learn about this stuff.
Dave
NO DON'T USE A CROW BAR with Vans Alternator
FrankK90989 said:
Hi , I doubt if your alternator has built in OV protection, but again it might be something new. yes a runaway alternator will let the smoke out of the nice things in your panel. I think B&C has OV "crowbar" http://www.bandcspecialty.com/
Regards Frank
Frank they do have OV protection. The crow bar is a bad bad idea with internal VR alternators.
The internal VR has an IC chip that includes all the functions needed to protect from a list of possible conditions:
>SHORT-CIRCUIT FIELD PROTECTION
>SHORT-CIRCUIT LIGHT PROTECTION
>SHORT-CIRCUIT CHOKE (ACTIVE LIGHT)
>SOFT-START FREQUENCY 100HZ
>LOAD RESPONSE, 10 SECOND DELAY
>PULSE WIDTH MODULATION
>PASSES FULL LOAD DUMP
>OVERVOLTAGE, UNDERVOLTAGE, BROKEN-BELT and FAIL-SAFE INDICATOR LIGHT FUNCTIONS
>LOSS OF SENSE INDICATOR FUNCTION
>BIPOLAR TRANSISTOR
>TEMPERATURE COMPENSATION PERFORMANCE (-10MV/C)
A lot of the mis-information and myths are based on old ideas. A few other folks (not Frank) with a big soapbox perpetuate myths about internally regulated alternators, like they have no OV protection. That's totally NOT true and just ignorant. Also claims they are prone to wild "runaway" OV conditions are ball face lies with no documented cases. Yes ND alternators can fail, but they are mild or benign failures. Despite sensational comments like "smoke from your panel" or a B&C sales pitch, "On a dark stormy night your panel goes dark", internally regulated alternators are extremely reliable and safe, provide you have adequate backup, wire and operate them appropriately.
Crow Bars needlessly damage ND alternators, which are NOT designed to use them. To use a "crow bar" with an I-VR alternator, you ALSO need to add a circuit breaker and a big (master sized) relay on the output lead of the alternator (called B-lead). THIS is a lot of extra STUFF, cost and WEIGHT you are adding to an alternator that has internal OV PROTECTION. IT IS NOT NEEDED.
OK you have a crow bar on your ND alternator: "OV relay" on B-lead gets power thru a CB and crow bar attaches to the CB. If an OV is detected the crow bar SHORTS to GROUND! :eek:, POPPING the CB, cutting the power to the relay which than opens the relay (creating a big spark). OK it is all good if you had a real OV, but the problem is the CROW BAR has a nuisance trips or faults trips. This happens while the alternator is running, under load (high output). The abrupt cut of the b-lead (output) causes a huge voltage spike or LOAD DUMP. This will FRY the alternator. It has happened many times.
Hear are the facts and two guiding principals of safe alternator operations:
1) Do not run the alternator unless connected to a battery
2) Do not short or cause arcs in the wiring of the alternator.
THE CROW BAR GOES AGAINST BOTH OF THE ABOVE: 1) cuts battery from alternator, 2) Creates a large arc (internal to relay). While the crow bar shorts, it opens the relay.
Here is my suggestion:
1-Wire the NipponDenso alternator as in the application it's designed for. I HIGHLY recommend you wire in the warning light, and the remote voltage sense. The warning light is an important feature and Van ignores this. USE it. Why not? Also use the remote voltage sense by connecting direct to the battery. Van suggests you tie the IGN wire and remote sense together, which is OK, but to get the best performance from the alternator use it. Not all ND alternators have this function, but if it does why not use it. (VAN SUGGESTS A SIMPLE WIRING OF THE ALTERNATOR WHERE THE WARNING LIGHT AND REMOTE VOLTAGE SENSE ARE NOT USED. It will work this way, but recommend using the warning light at least, see ref below.)
2-Operate the alternator as it was meant in the application it was designed for (CAR). DO NOT MANUALLY TURN IT ON AND OFF THRU THE IGN WIRE POWER LEAD. The way the alternator should be used is, BEFORE engine start apply power top the IGN lead (with the master BATT switch). AFTER engine shut down turn the IGN lead off (with the BATT master). Builders are doing weird things like starting the engine with the alternator off and turning the alternator on manually after the engine is turning the alternator. This is not how it works in a car and not the intent of the IGN wire. The IGN wire comes on with the master and off with the master. If you have a problem and shut the alternative down you can turn it off then. HOWEVER the IGN wire cannot be used or trusted to shut the alternator down for a non-normal condition. (SEE NEXT PAR, item 3)
3-BIG MIS-CONCEPTION, The IGN wire is NOT a "Field Wire". The IGN wire is a Come alive or Go to sleep wire for VR power. That is it. Now some people will tell you that IF (and that's a big IF) the VR goes crazy (for a very rare and unlikely reason) you would have NO control. In this scenario the IGN wire will NOT turn the alternator OFF. This is TRUE. So how do you control an OV condition? THERE IS A SIMPLE SOLUTION: IT IS CRITICAL THAT YOU PUT A CIRCUIT BREAKER ON THE B-LEAD (alternator output), MOUNTED IN THE PANEL YOU CAN PULL. Think of it as a manual crow bar. IF for any reason the alternator is not stable or working properly you can reach over and pull the alternator's OUTPUT CB and ISOLATE the alternator positively from the aircraft. Alternator problems have signs well before a super NOVA. Have good gauges and Hi/Lo warning lights. Don't rely on the IGN wire to control the alternator. (I know it's popular to use FUSES you cannot access or replace in flight, but this concept is NOT compatible with I-VR alternators, at least use a CB for the b-lead.)
4-If you have an all-electric airplane, electric depended engine (electronic ignition / fuel injection), full EFIS panel, heated pitot and all the lights-bells-N-whistles, DONT install a 35-amp alternator. Vans alternator is rated at 60 amps, BUT it may not be big enough. It really is a 55-amp alternator. IT IS GOOD PRACTICE NOT to load the alternator continuously over 1/2 to 2/3rds of rated power. Most can live with this. However if you need more, ND has some nice alternators that put out 80 to 90 amps that are not much larger and will fit just fine. Heat kills ANY alternator.
5-PROVIDE COOLING AIR TO THE BACK OF THE ALTERNATOR. ND alternates have efficient internal dual fans and shield. However the max ambient temp is a little over 250F. Try to provide air and a heat shield between exhaust may not be a bad idea. The radiant heat from a 1400F exhaust pipe a foot away is not helping. If you keep it cool and don't over tax it the alternator will last to TBO, easily.
6- IT'S A BIG LIE THAT I-VR ARE PRONE TO SERIOUS FAILURE. I researched this and found stories of OV where just that STORIES. OV stories are left over from the OLD external VR alternators in Cessna's & Pipers. These aircraft are using 1950's technology and did have OV problems. Old VR's had mechanical relays to control voltage and no OV protection. THEREFORE THEY NEEDED AN OV MODULE ADD-ON LIKE. Many old timers think I-VR are based on this technology. FACT, an internal VR has an IC chip, with both analog and digital function, using 100's if not a few 1000 equivalent transistors. External VR's JUST regulate voltage and don't have the sophistication of INTERNAL VR's. Most E-VR's JUST regulate voltage, that's it and nothing more. A typical external VR (like the B&C unit) has 2 or 3 transistors and just a handful of other components. In fact the voltage reference in these plan external VR's use a simple zener diode reference scheme. Advanced I-VR have a much more stable voltage reference incorporated in the IC chip. There are modern external VR's, but the one B&C sells is not one of them.
WHY are all modern alternators in cars equipped with I-VR? Don't cars have expensive on-board computers and sensitive sensors (airbags) that need OV protection? Yes. That's why auto alternators have good OV protection. LOOK :eek: I checked the NATIONAL HIGHWAY SAFETY FOUNDATION database. This tracks all automotive related safety issues: Consumer complaints, Service Bulletins, Recalls, accidents related to vehicle defects. THERE HAVE BEEN NO COMPLAINTS AGAINST the alternator Van sells. This is not true of many other brands of alternators, which do have problems, but in general the ND alternator BRAND is the cream of the crop. The alternator Van sells is common in late 80's early 90's Suzuki and Geo cars. Variations of this model are found is 100's of thousands of cars and industrial equipment (forklifts, tractors) all over the world. These are going 24/7 all year round with great reliability. Some ND alternators have over 8-10 years of trouble free service in homebuilt planes. My two Acuras have a combined total of 400,000 miles and 25+ years of service, both have ND alternators still going strong.
Small Suzuki and Geo alternators are not made new anymore by ND, because today's cars need more power, even a Geo. However the new high power ND models are just larger variations of the smaller units. This leads to a point about rebuilds that some may not know. Not all rebuild alternators are the same. Pick your supplier carefully. I don't know who Van uses but you can get all new units made with after market parts. Not all rebuilds use genuine ND parts. Many aftermarket manufactures make rebuild parts. Good bad or indifferent it is something to think about.
I have checked many of the OV STORIES that I-VR allegedly had. They usually go like this: "I have a friend, and he knows some one who had an over voltage in his ND alternator in his Cessna 172." Well there are no ND alternators in factory planes. Tracking down the facts, they have nothing to do with a ND alternator or over voltage.
LEAVE THE CROW BAR OFF AS VAN SUGGEST.
George
Can you get some real FACTS?
PapillonAir said:
A fellow EAA'er at our local chapter just had a horrendous experience with the alternator you mentioned... things were going fine till he happened to switch off and on his alternator in flight, when all heck broke loose! and he fried about 9k worth of his brand new panel! He did not have external over-voltage protection! I personally installed the BC Specialties system mentioned in the above replies in my "6" and am very happy that I did this, I would have a local alt. shop remove all internal voltage regulation from your alt. and go only with the BC Spec. regulator... not only does it have fail-safe over voltage protection, but it also has a nifty way to do fine tuning on your alternator voltage output...
Good luck
Dale - RV6 N833DW
Not picking on you but where are the facts?
Why did he turn the alternator off in flight?
What alternator, what model number?
What part failed?
Turning the alternator off caused a problem??
Why did he turn it off again?
Something sounds fishy here. I mean it gets your attention and is very sensational. I am not saying it did not happen, but there are some serious holes in this tale of horror, which is typical. Lets say there is some truth to it. The pilot sounds like he induced the issue but turning the alternator off under load. I really have no idea, but that is the point. There is no real data or info here, just a story. The $9,000 part sound like an exaggeration.
I know B&C would love to make this true to boost sales.
Looking at my RANT and RAVE above you should never turn a good alternator off while running under load. Master and ALT are tied together. Put a pull-able CB on the IGN wire for non-normal shut down, if you ever need to. Otherwise: (master ON, ALT on) - (master OFF, ALT off).
"IT SMOKED $9,000 WORTH OF RADIOS" I doubt that; first most modern avionics are made to a standard that allows them to survive overvoltage and can operate from about 10 volts to 32 volts continuously. Also they can survive spikes over 60 volts. Check the specs for your radio. Also if these radios are subject to severe over voltage it would burn out the power supply. Yes it would cost to get fixed but $9K, I don't think so. There are some old radios that would be damaged but still this sounds like a tall tail.
ALSO OV is a term used loosely. There are two semi documented cases where Van's ND alternator went over voltage, to about 18 volts. 18 volts is the over voltage set point of the ND alternator. Normal regulated voltage is +/-14.5 volts. In the two cases where the ND alternator started to act up the voltage rose to 18 when with alternator low load. Clearly the alternator was not working properly. IN BOTH CASES THE PILOT PLAYED AROUND WITH TURNING THE ALTERNATOR ON and OFF UNDER LOAD. NEVER DO THIS. YOU ARE MAKING VOLTAGE SURGES, SPIKES AND LOAD DUMPS.
What is a runaway overvoltage? Well it is a myth. It happens but again none I know of involving a ND alternator. Again if your Blue Mountain EFIS is destroyed with 18, 30 or even 60 volts I would return it. I know for a fact that the Dynon EFIS is protected to 60 volts. I also know if it's subject to an extreme over voltage condition the repair would be of nominal cost. (I asked)
Bob N. mentioned an anecdotal story like this on the Aeroelectric list, with no facts either. He ignored repeated request to get more info, despite his claim he was looking into it. I am sure if Bob found a smoking gun he would have wrote it up to epic levels. I think this is the same Legend.
I suspect this second hand story you mention is under the myth, urban legend and even a little duplicitous.
The thing that makes me mad is the lack of REAL good data and honest debate. People support B&C and make money at it. Great. Don't get me wrong, it is a fine product, but many B&C customers have had problems, not the least of which is the crow bar. The real comfort level with the B&C method is it's DIRT simple and easy to understand. All good attributes to be sure, and I appreciate it. There is a comfortable understanding of a simple VR circuit with 3 transistors, connected to a crow bar with another 2-3 transistors. That's cool, but there are no guarantees it won't fail, or the crow bar will fail passively, with out the pilot knowing it. I believe the crow bar also requires periodic testing to assure it will work if need. That would not fly on a Toyota. An electrical system, except the battery, should be basically 100% maintenance free.
Sensational stories are fun but of little real use, unless we have detailed facts of what and how, where, when, why it happened. I don't have an agenda, but I want the truth for others to make an informed choice, not an emotional one. I can say, in my opinion, if you are day VFR, with an engine not dependant on electrical power, by all means keep it simple, light and less expensive , use the I-VR ND alternator as is.
George
**There are some E-VR's made for marine or heavy duty vehicle use with advanced technology. Advanced E-VR's with internal OV protection, adjustable voltage control and fault monitoring can be had at 1/3rd the price of a B&C unit.
gmcjetpilot,
That was a very well thought out reply. I suspect you went thru much effort in the past to get to the bottom of this.
I in return am a complete ignoramus when it comes to electrical .
What you say does make a lot of sense though.
Where could I get a wiring diagram which shows exactly how to wire in the CB and the warning light ?
Thanks again for the enlightening reply.
How about posting a wiring diagram
gmcjetpilot said:
1-Wire the NipponDenso alternator as in the application it's designed for. I HIGHLY recommend you wire in the warning light, and the remote voltage sense. George
Not knowing any better, I just wired mine they way they told me. A warning light would be a heck of a good idea! Which wire is it? And what is the "remote voltage sense" wire for? I thought that's what the one that had me hook up to the alternator switch was for.
How about posting a wiring diagram?
Here's a section from Toyota's training manual, which appears to use a very similar alternator. There are diagrams that show how the alternator operates before the engine is turning, during normal operation, when the S lead becomes disconnected, and when the B lead becomes disconnected. There's even a self-test at the end. :)
http://www.autoshop101.com/forms/h8.pdf
Now I'm going to go do some actual work.
It takes all types...
Geez, sorry folks, did not think that my comments would cause such a reply!
That WAS my experience, and that is what I had heard from others, so since I do not appreciate being called a liar, I will refrain from any future comments in this section.
I thought that RV'ers were suppose to be nice folks?
Here are my favorite alternator LINKS
Here are great links about the ND in particular and alternators in general:
Overview of ND alternator and wiring
http://www.autoshop101.com/forms/alt_bwoh.pdf
More specific ND info (wiring) troubleshooting as installed in a Toyota
(not all ND alternators have remote V sense)
Niagara has a good dwg showing the warning light (ND w/ out remote volt sense)
http://www.niagaraairparts.com/alt-instr.pdf
Good General overview of alternators
http://members.1stconnect.com/anozira/SiteTops/energy/Alternator/alternator.htm
Remote Voltage sense and Why
http://www.madelectrical.com/electricaltech/remotevoltagesensing.shtml
The Nitty Gritty, Basics of alternator & regulator theory / physics: electromagnet, magnetic FIELD, 3-phase AC, stator, rotor, rectifier and voltage regulators:
Fundemental Physics of alternators, with animation
Inside of Typical internal Voltage regulator
http://www.freescale.com/files/analog/doc/data_sheet/MC33099FS.pdf
_OR_ more detailed spec sheet (see page 2)
http://1url.org/go/1gx7qm
I mentioned that I don't like the crow bar (with I-VR alternators) due to possible faults trips that can damage the alternator. Since the alternator has OV protection and the chance of it happening is slim to nil, why put it on. However if you MUST add it on for comfort, I agree with a previous post, the periheliondesign's OV protection device should be more stable:
http://www.periheliondesign.com/LOVM.htm
Enjoy, This should answer a lot of questions. The fun part of building is learning. I know I have. Cheers George
Dale, my apology
PapillonAir said:
Geez, sorry folks, did not think that my comments would cause such a reply! That WAS my experience, and that is what I had heard from others, so since I do not appreciate being called a liar, I will refrain from any future comments in this section. I thought that RV'ers were suppose to be nice folks?
Dear Dale:
My sincere apology if you thought you where being called a liar. I am nice and at no time did I call YOU liar. I did state that the I-VR thing is ripe with stories presented as facts (lies) as in.....A false statement presented as being true; a falsehood.
This was not the case here. You clearly presented a story you heard and stated so. However some repeat stories as fact and can not provide any detail. Again, I just like to know what really happened and why.
The story you related you stated was second hand. It may have been 20th hand, I don't care. What I do care about is getting useful INFORMATION to improve safety for everyone using internal VR alternators. WHY MAKE THE SAME MISTAKE IF IT CAN BE PRESENTED. If this happened than why? It would be great to hear from the person it allegedly happened to.
This story and many others do have holes; this is in no way an indictment of you Dale. It does represent my frustration with something that is so important, as flight safety, being polluted with rhetoric, which is not your fault. You clearly made your statement, which in turn brought up a good discussion. I DO NOT have all the answers but would like answers. I try to back my opinion up with facts. I could be wrong, and if corrected I would be happy to learn. That is important. Bottom line WHAT IS THE BEST WAY TO USE AN I-VR ALTERNATOR IN YOUR AIRPLANE?
I did appreciate your post Dale and your experience with B&C. It was quite clear you made the statement in good faith to help.
Again, sorry if you took it wrong and apologize if I offended you.
Sincerely George
Apology Accepted
George et. al.
When I said "second hand" I meant that I had heard it directly from the guy that had the problem, so now that I am passing it along it is now second hand info.
The guy is not an "on-line" type of person, I do not think he even owns a computer. He is an experienced RV builder and this problem was with his second RV project - first was an RV4 which he has been flying for about 10+ years, the recent, and problem aircraft was his version of a "super six" which started life as an RV6 but now is much more. I belive he had roughly 30+ hours on the plane with no problems, had done his FAA fly-off and even had taken it to OSH this past year. The problem he related was on a recent flight, cruising along with everything normal, he decided to secure the alt. switch to see what sort of batt. capacity he would have available should he lose the alt. output (which I think is one of the reasons to have control of the alt. output, in addition to trouble shooting or securing a mis-behaving unit). He stated (in front of our chapter meeting) that as he re-activated the alt. he almost immediately got smoke in the cockpit, along with the little trim indicator meter literally blowing up and shooting out sparks and smoke!, all his "Vans" panel instruments were totally dead. He re-secured the alt. and got the thing on the ground asap. He then went on to indicate that the alt. he purchased from Van's was indicated to have internal voltage regulation and OVP. So, he was not really sure just what had happened, he found all his Vans engine instruments were melted / smoked with bad smells, and all other instruments / avionics having trouble or inop. So, at the point he reported, he indicated that he had smoked about 9k worth of stuff, but was getting some good news from the avionics companies that were able to repair a lot of the damage, so he closed with the statement that he now will be going with the externally regulated type alt. and hopefully not having to go through this again. At this point in the meeting, a close friend of his stood up to expand on his understanding of the problem, I think this guy is an electrical engineer - or at least gives that impression. He drew all sorts of diagrams on the board and related that there are two basic types of control circuitry used on all internally regulated alt. on the market today, he went in to more detail on which type the problem aircraft probably had, and why the problem most likely occured. He indicated that from the damage he saw, that the alt. output had easily exceeded 2-300volts, which is why so much damage had been done, in that the fuses in the aircraft will only protect from over-current situations and not over-voltage. He indicated that in most situations that the internal systems work just fine, but the one type, can at times, if certain internal problems exist, go in to a run-away situation should the control lead be de-energized / re-energized - which is what the owner inadvertently introduced in this situation.
Now, in my own experience, when I purchased my alt. kit from Van about 4 years ago, all that they had was the non-internally regulated types and you were on your own to get something for regulation. I was aware of the BC unit, so I purchased that one as opposed to "experimenting" in trying to use some sort of automotive unit, which may have all sorts of specialty neuances.
The system worked great for me, except for at about 5 hours on the plane, my alt. bearings began to sing / and being ultra cautious at this point of any strange noised eminating from under my cowling... I chose to remove the alt. for inspection. I took in to a local auto alt. shop for testing and sure enough they found that my "brand new - rebuilt" alt. from Vans had bad bearings in addition to them finding the brushes almost worn out too... $55 later, had both replaced... my call to Vans was met with "will send you another but you will have to pay full price" Now, I do understand that the thing was a re-built from the start, but still disappointing none the less. So, in the time since then, I guess they have switched over to the internally regulated type... so, with my experience with the alt. it did not really suprize me that something had gone wrong, and made me really glad that I had the external ov protection!
My intentions were to just point out that problems can develop, and my eperiences with the BC ovp have been fine... of course I had no option when I purchased my alt.
I guess the bottom line is here... if you have an internally regulated alt. you had better not be shutting the thing off in flight with the old circuit design of having a separate alt. switch ie. the Cessna split master switches.
Dale,
Should you have further questions, and as to not bore the viewers to death you can contact me directly at drwittman_at_comcast.net
I have been using IR Denso alternators for over 20 years in street, race cars and aircraft. In both race cars and aircraft, we shut off the field wire via the kill switch or field switch. Never had an ND alternator fail yet from doing this.
Thak sounds like an Ouch
QUOTE=PapillonAir: George et. al.
Thanks for getting back with more detail
Absolutely, but only IF the alternator was misbehaving. Normal operation no. There is NO reason in my opinion the TEST the battery by turning the alternator off. There are load test you can do with them to determine their capacity. THIS IS IMPORTANT. A GOOD BATTERY IS SO VERY IMPORTNAT to a healthy electrical system. IT is not only for starting the engine and reserve power, it is the buffer or filter between the alternator and the BUSS.
LED's will blow easily with too much voltage, no kidding with a little bang and smoke. Van's gauges (I hate to be negative) are let's say built in the most cost effective way w/ no internal pwr filtering.
He found all his Vans engine instruments were melted / smoked with bad smells, and all other instruments / avionics having trouble or inop. Some good news from the avionics companies that were able to repair a lot of the damage, so he closed with the statement that he now will be going with the externally regulated type alt.
Yes the expensive stuff should have protection but don't always count on it. Old avionics allow outside supply power go direct to a "main board", unlike newer stuff. However some low cost stuff like the ICOM com radio (which I have and like) does not have internal protection, but it only cost $700.
I have come to the conclusion from hearing this incident and two other stories (which where minor but similar in that the pilot turned the Alt on/off under load), the common thread is switching the alternator while running. So if you don't do this you will have no problem? (rhetorical question).
At this point in the meeting, a close friend of his stood up to expand on his understanding of the problem, I think this guy is an electrical engineer - or at least gives that impression. He indicated that from the damage he saw, that the alt. output had easily exceeded 2-300volts, which is why so much damage had been done, in that the fuses in the aircraft will only protect from over-current situations and not over-voltage.
TRUE, 200 volts would be the high end for a little ND alternator, but alternators can burn out before reaching the absolute max. Regardless this was a true OV case without doubt. The theoretical max voltage is based on diode/wiring rating of alternator. Also the battery will absorb the over voltage and moderate it somewhat. A high/lo voltage warning light is critical an aircraft. Even with a B&C crow bar, there's a time delay to "Pop" the CB, plus the reaction of the relay magnetic field to collapse and open the relay.
It would be nice to pull the regulator and see what has failed. Does he still have it? I would like to evaluate it and would pay shipping. They are sealed units but they can be pried apart. Actually having the whole alternator to analyze would be best. Any chance of getting hold of the damaged alternator Dale? Again I would pay shipping and return it when done.
The system worked great for me, except for at about 5 hours on the plane, my alt. bearings began to sing / and being ultra cautious at this point of any strange noised emanating from under my cowling... I chose to remove the alt. for inspection. I took in to a local auto alt. shop for testing and sure enough they found that my "brand new - rebuilt" alt. from Vans had bad bearings in addition to them finding the brushes almost worn out too... $55 later, had both replaced...
The expert seems to have insight, but I wonder specifically what internal problem? I do know the single fault point in the ND alternator is (in theory) the drive transistor to the FIELD. The ND alternator has a "A type alternator. One side is connected to positive (all the time) and the ground side is controlled thru a transistor controlled by the VR. In theory the field transistor fails causing a dead short to ground, bypassing VR control. With full voltage in the field and high RPM you the output goes very HIGH, which in turns excites the field more, thus runaway up to the physical limitation of the windings/components. The chance is better your prop will depart the engine. Also transistors fail open as well, which is a non event. The mean time between failure (MTBF) of transistors is millions of hours, and it's very over rated for the duty it sees in the alternator. Does cycling the alternator power instantaneously fry's the field transistor shorted out? I guess it's possible, but not sure exactly how or why, unless a post mortem is done. (My offer stands to examine it).
Van has sold the early 80's Honda/ND 35 amp alternator as long as I can remember, I think the one you have Dale and the 55/60 amp ND with I-VR. The 35-amp unit is designed for external regulation and a single cooling fan on the front, that for some reason Van takes off (cowl clearance?). Over the years Van has had (does have?) ?quality? issues with both alternators. I know some alternators that arrived DOA. You can buy them cheaper at an auto part store than what Van's sells them for. Based on track record my be other sources can do better. The problem is 35-amp is not enough for some builders who need more power with all the electronics used today.
Not all rebuilds are the same. There are 100's of local and several large rebuild companies that dominate the market nationally and worldwide. There are even more makers of aftermarket parts. It's possible sub-par repair parts are made not meeting OEM standards. While some aftermarket parts are fine, as good or better than OEM specs.
I AM VERY suspicious of the brand of alternator Van sells, the re-builder and the (aftermarket) parts inside. It seems Van my have gone with Low bidder. All the problems I am aware of came from Van's. As you say Dale, it?s not the first time I?ve heard parts are worn and apparently not replaced in the overhauled units! Original new ND alternators are obviously superior to rebuilds (no kidding). The 55/60 amp ND Van sells is not sold NEW all genuine ND anymore because they are not in production (89-95 Suzuki). However the industrial applications in current production can be found NEW. These NEW all ND alternators are mostly in the 45-amp size. I have a new genuine ND. It is like the Niagara unit. I am day/night VFR so I can get by with 45 amps. I could remove the I-VR and convert it to an external VR but I saw no reason to do it for my application. Since many need weight on the nose of there RV there is no reason to not use a 80/90 amp unit. Most come with serpentine belt pulleys, but easy to change to V-belt. They should fit and weigh a pound or so more. It's easier to find NEW in late model car units. Late model cars use alternators with more than 60 amps, that I know of.
My intentions were to just point out that problems can develop, and my experiences with the BC ovp have been fine... of course I had no option when I purchased my alt. I guess the bottom line is here... if you have an internally regulated alt. you had better not be shutting the thing off in flight with the old circuit design of having a separate alt. switch ie. the Cessna split master switches.
Excellent point. I personally don't think there is a good reason to cycle the ALT. I use a DPDT (double poll double throw) switch that always turns the master BATT on and ALT (IGN wire) ON and OFF at the same time (always). Even a split Cessna unit allows inadvertent shut down of the alternator. IF you want to disable the the ALT while the BATT is still on you pull the ALT circuit breaker (CB), which you should have in series with the switch. I also have a CB on the B-lead. So in-case of Oh-Damn you pull the B-lead CB. That is my main way to isolate the alternator, not the ALT switch, with an internally regulated alternator.
Dale,
Thanks Dale, that explains quite a bit.
