backcountry
Question: Do you happen to know when you get your pitot static altimeter check IFR.Do you have to get the back up altimeter also certified.
The shops double the price for two altimeters.
AOPA couldn’t answer the question when it comes to what the regulations say. They thought if it’s experimental you could do whatever you want but I’m not sure that correct or not either.
