Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
05-09-2023, 05:38 PM
Dimple cracking caused by laser cut holes
Used to be all your final-sized holes were punched, you would knock off a slight burr, and be good. Now that Van's is using laser cutting, each and every hole has a notch. Eliminating the notch requires deburring to such an extent that it would oversize the hole. So instead, you just have to deburr as much as you are willing, and hope the hole doesn't crack when dimpled.
Well, here's what hoping will get you
Come on, man!
RV-14A - N74LF reserved
Emp started 1/1/22 - 85% done
Wings SB started 4/14/22 - 85% done
Fuse SB started 1/8/23 - 10% done
Finish ordered - crating Winter '23
05-09-2023, 07:33 PM
Ugh. That is unacceptable.
05-09-2023, 08:21 PM
If the notch exceeds the .125 dimension, I would request an RMA and replacement. If quality work, you can anticipate a 30+ yr lifespan granting you a decent ROI.
I'd question that service-life estimate if a notch is present.
05-09-2023, 08:34 PM
Agree, I’ve replaced at least one laser cut part, and still had some light file work to do after reaming and dimpling. It the ones I couldn’t see that worry me as well.
Brian
RV-14A
Build Started 12/31/21-
Section 6-10 complete 3/19/23
*Emp Ordered 9/27/21- Delivered 6/30/22
*QB Fuselage Ordered 11/3/21- Est Sept 23
*QB Wings Ordered 2/18/22- Est 3Q23?
*YIO-390-EXP119 Engine Ordered 5/14/22- Est 1Q24
*Prop Ordered 5/20/22- April 2023 delivered
*Finishing Kit ordered 6/25/22- Est 3Q23
*SteinAir Panel delivered 6/26/23
https://eaabuilderslog.org/?s=RV14A2021
PA-28-236 N419SB
KIWS
VAF donation 2021/22/23
CAF Member
EAA Member
AOPA Member
05-09-2023, 08:35 PM
How about a "before" picture?
2022 Dues paid!
05-09-2023, 08:51 PM
I have one, this is as received, even has burn marks. Had to ream and even then, had to pull the reamer to the notch side to clean up the nick. Watch your laser cut parts carefully!
Brian
RV-14A
PA-28-236 N419SB
KIWS
CAF Member
EAA Member
AOPA Member
05-09-2023, 10:08 PM
I’m also seeing holes that contain the little notch depicted in the picture above. I guess I haven’t really thought about how much notch is unacceptable? I understand a cracked dimple is grounds for replacement, but what about the ones that don’t crack initially? What are the odds we are going to be seeing an influx of crack repairs coming from the Mothership in the next 5-15 years?
05-10-2023, 12:15 AM
I admit that I am worried about this. I'm not 100% festidious about addressing the little notches, as you can see in the original picture, because it would be literally every hole. I deburr, but nearly always a small notch remains. Final drilled was supposed to mean hole prep work was minimal. Addressing these laser cut holes may turn out to be nearly as bad as having to match-drill everything.
05-10-2023, 07:27 AM
I share your same concern. My current -10 build is my first RV and I am starting to think these laser cut parts are going to be problematic in the future. It is completely unrealistic to dress the notch out of every single rivet hole. Most of my laser cut holes are pretty clean but they all possess a little”pool” of what appears to be once molten metal.
I sure hope these airplanes started in the 2022ish timeframe don’t end up being known as “Covid Era” builds with airframes riddled in stop drilled holes and ultimately undesirable on the resale market.
05-10-2023, 10:42 AM
They are using a bad strategy with the cutting. They should start close to the hole center and then spiral outward, that would not give a notch. Someone is saving a fraction of a second in cycle time by starting at the major diameter and then creating notches on every hole. A strong message needs to be sent to management.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
