VAF on Twitter:
@VansAirForceNet
Old 06-19-2022, 10:48 AM
Teal Teal is offline
Default RV9 200HP Yamaha Sidewinder
Hello everyone,
I removed a Lycoming 0-235 from my RV9 and installed a Yamaha Sidewinder snowmobile engine. I know, I know I'm crazy what did you do that for....etc. The engine currently in stock tune on the fully programable ECU is set a little over 200hp from sea level to about 10kft. Currently at 15kft I can still make about 165hp according to the engine display.
It will climb out of my 1000MSL airport at over 2500FPM and at 15kft it will still climb at about 2000FPM.
Currently I can not maintain full throttle with OAT's above about 75f but I am installing a new radiator soon that should cure that.
I currently have only 7 hours of testing but the numbers are really great so far. The weight is 31lbs lighter with this engine over the 0-235 but I added the constant speed propeller. I also used the OEM cat iron exhaust manifold since I needed the weight. I pushed the engine away from firewall and used the stock turbo location which is between engine and firewall. Pushed the battery out on the engine mount and the CG ended up within .2" of the previous CG.
Biggest challenge currently is keeping the engine from overheating during Taxi but I will be adding radiator fans shortly for that.
I do not have real good fuel flow numbers yet at the lower Hp's. I know that it will burn 19GPH at wot anything under about 12kft. but that will yield a true airspeed of about 205MPH.
I am currently unhappy with the propeller blade selection for high altitude performance. It seems that there is not enough blade surface area to absorb the HP in the thinner air. Currently shopping for other options.
here is a few pictures of the install and the aircraft.
http://https://www.dropbox.com/s/ocl...r /> .jpg?dl=0
https://www.dropbox.com/s/ptfvkkhmwu...82354.jpg?dl=0
https://www.dropbox.com/s/jruwz1yu24...35945.jpg?dl=0
https://www.dropbox.com/s/qi04xaqg8c...mount.png?dl=0
Old 06-19-2022, 10:54 AM
Foghorn's Avatar
Foghorn Foghorn is offline
That’s pretty cool! Please keep the info coming. I’m holding out for an affordable turbine. 😳
Jeff Parker
RV8 Fastback (Tom’s Dream) - Phase II (N767TS)
C195 (Red Dawg) - Flying (N4469C)
Retired Army CW4 - Helicopters, KingAirs, B737, MD11
Old 06-19-2022, 10:55 AM
Dad's RV-10 Dad's RV-10 is offline
Pics posted from Dropbox link:
Click image for larger version
Old 06-19-2022, 11:03 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Teal, welcome aboard the good ship VAF
Congrats on the successful conversion to the Yamaha.
Did you consider the factory VNE numbers??? Methinks you are very capable of blowing well past them.
Good luck with the continued test, and please keep up with the reports.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-19-2022, 11:08 AM
PilotjohnS PilotjohnS is offline
Default Bravo
Bravo, bravo, well done.
Please keep it safe.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
Old 06-19-2022, 12:06 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Keep up the reports! I have flown other aircraft with the Yamaha engines, and have wondered when someone would try one on an RV….so it will be great to hear your experiences. As has been pointed out, watch those TAS Vne numbers….and have a blast!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-19-2022, 12:52 PM
blaplante blaplante is offline
Default Reduction Drive?
Is the reduction drive from Yamaha? Is it designed for the thrust load?
RV6A in phase 2 as of April 2016
Donation made Dec 2022
Old 06-19-2022, 12:58 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Very cool! Keep us updated as you build more time on it.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 462.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 06-19-2022, 01:09 PM
DanH's Avatar
DanH DanH is offline
Your latest gearbox Teal?
https://www.skytraxusa.com/
https://www.skytraxusa.com/new-page-1
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2022, 01:10 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
That looks very well done. It would be great if you keep us updated.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
