Keep VAF
Going
05-12-2022, 02:11 AM
With Autopilot on right wing sits lower.
Hi,
Whenever, I have Autopilot on, either using a NAV, heading or track the axes (tilt) of the aircraft is slightly lower on the Starboard wing (slightly higher port wing).
However, with the Autopilot not engaged the aircraft is level.
Any suggestions for the cause and correction would be appreciated.
Regards John
05-12-2022, 02:42 AM
I've seen something similar with my GRT when the ball is not centered. When I center the ball, the wing comes back up.
Which AP are you flying? Is the ball centered?
05-12-2022, 02:52 AM
The avionics is all Garmin. Not sure about the ball in the 2 scenario's -will check on next flying visit.
05-12-2022, 04:38 AM
I agree with Mickey, I've had the same thing when the ball wasn't centered.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
05-12-2022, 04:42 AM
Yep, roll compensating for a yaw offset.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
05-12-2022, 06:04 AM
Yep--- Ball not centered. When it does that, try to add a little rudder to center the ball and I bet you will see the wing come up.
Keith
Keith in Lacrosse WI area
Finished Wittman Tailwind in 2016
Flew RV9A and RV6a while building
lurking for years but now paid
05-12-2022, 06:56 AM
Yaw
Does your autopilot have a yaw damper?? If so, maybe that system is not set up right.
Sonex/Corvair 2016 Finished, Sold 2020
RV-9A 2005 Purchased
IO-320 160 hp
Exempt but happily paid for 2022
05-12-2022, 07:54 AM
Moderator, Asst. Line Boy
With the autopilot engaged, you have more electrons in the roll servo and associated wiring. This makes the right wing heavier.
Just kidding. Couldn’t resist.
Scroll
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
05-12-2022, 10:31 AM
Hi,
No yaw damper fitted. I will make sure the ball is centred during my next flight and report back.
Regards John
05-12-2022, 11:53 AM
Rudder trim
I always wondered about rudder trim on the 7, 8 and 9 series. Curious how many Vans builders have installed rudder trim?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 70%
www.pilotjohnsrv9.blogspot.com
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
