Old 06-13-2021, 03:39 PM
VF84Sluggo VF84Sluggo is offline
Question Tempest Fine Wire Spark Plug Cleaning
I pulled my Tempest fine wire plugs as part of my oil change. I notice that some have a buildup of carbon on them. Is soaking the plugs in MEK to loosen up the crud, then using an old toothbrush to brush it away an acceptable practice? I don't think the bristles on an old toothbrush will hurt the plug tip and electrodes, but I'm wondering if MEK will damage the plug.
Thoughts on this?
Old 06-13-2021, 03:46 PM
Plummit's Avatar
Plummit Plummit is offline
MEK shouldn't hurt the fine wire plugs but all you really need to do is use a dental pick to clean the lead out and re-install with new gaskets.
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-13-2021, 03:51 PM
-Marc
Thanks, Marc. I need to get one of those. Sounds like I'm making this harder than it needs to be.
Old 06-13-2021, 04:16 PM
rmarshall234 rmarshall234 is offline
The fine wire is extremely hard and *brittle. Do not touch it when cleaning or you run the risk of breaking it and buying a new plug.
Old 06-13-2021, 04:23 PM
BillL BillL is offline
I found your helmet, about 2/3 the way down.
Or ctl-F and search Sluggo.
Bill
RV-7
Old 06-14-2021, 07:39 AM
Talking
Well I'll be! There it is
