Old 01-12-2021, 01:47 AM
pierre smith's Avatar
Default Lifting fuselage
Morniní guys/ladies,
My Finish kit is on order and Iím curious about how to raise the fuselage in order to install the landing gear. The tail cone is not attached yet, per Vanís advice. I have a forklift and an overhead hoist.
How did you guys do it?
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 01-12-2021, 03:42 AM
rleffler's Avatar
rleffler rleffler is offline
When I lifted my RV-10 fuselage, my son and I just picked it up and placed it on an EAA workbench. Getting off the workbench was a little more interesting, but not a big deal. Simply slide it forward and let gravity assisting until the nose wheel touched. We did have an extra person available to pull the workbench out of the way to lower the mains.
If you had the assistance of 2-4 folks, it shouldnít be that difficult for your rv-12 since itís lighter.
During the build, I used some 1 x 6 boards a few inches wider than the fuselage to to store the empennage hanging from the ceiling. I cut small notches in the end to place straps. The notches at the end prevent the straps from compressing the sides and held the straps away from the sidewalls. You could do something similar with your forklift.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-12-2021, 09:05 AM
lr172 lr172 is offline
With my 6 and 10, I used an engine hoist with a strap on the engine mount. Doing this, there is very little weight on the tail cone. Even my wife could hold it while I lifted the front and then set it on a saw horse. I put another saw horse under the wing spar carry through area and set it down on that for leg mounting.
Larry
Old 01-12-2021, 10:32 AM
wirejock's Avatar
wirejock wirejock is offline
Default Lift fuse
On my 7a, I use the rotisserie. I lift the tail and Sweetie puts a sawhorse under the center section. Then lower the tail and the rotisserie comes off the ground. If it needs to be higher, add couple of 4x4s under the rotisserie and repeat. That all ends pretty soon. Gear and engine will be going on.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 01-12-2021, 10:55 AM
Caummisar's Avatar
Caummisar Caummisar is offline
Was the engine mounted when you installed the gear?
VAF# 835
RV-7A /FWF/Engine Re-Mounted/Big cut soon
Slow build --- ALL THE WAY
Victim of SB-632-B
2021 Dues Happily Paid
Old 01-12-2021, 12:44 PM
AlpineYoda AlpineYoda is offline
My hangar has a forklift. I placed an old pallet under the baggage door / RV-10 rear step and I covered the pallet in cardboard and styrofoam blocks to protect the metal skin. I picked up the whole fuselage (no engine at that time, just complete tail and fuselage) inch by inch, testing that it would not easily rock off the forklift and fall, until it was high enough to insert the gear.
It did take me 3 or 4 tries to find exactly the right place for the pallet and lifting point to match the CG.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel in 2Q 2021
Flying fall 2021?
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
Old 01-12-2021, 03:17 PM
daveyator daveyator is offline
A 12 fuselage is pretty light. Got a friend to help and put it up on a couple of well padded, carefully placed saw horses and all was good.
Cheers, DaveH
